-   -   Power Window - still a problem! (http://forums.pelicanparts.com/porsche-911-technical-forum/286557-power-window-still-problem.html)
busteif 06-04-2006 06:15 PM
Let me explain this strange deal. I posted this issue 3 weeks ago and got a couple of directions about switches, etc.
I went out to my car - unplugged the passenger side switch on both driver and passenger side - plugged them back up and tried them out but no results, checked fuses/wires etc.
next morning got in the car and tried once a again and passenger side went up - 4/5 days went by no issues, until yesterday again passenger side window will not go up I press the switch up no sound, I press the switch down I get a single click ? now I'm definitely confused.
Please help. (driver side is fine) I even took both passenger side switches and tried them on driver side they work.
Help Help Help - :confused:
ChemMan 06-04-2006 06:40 PM
If you read my posts you will see I am no expert on windows-so take my advice accordingly. You could remove the panel and apply 12V to the window motor to see if it works. If it does, buy some new switches. They are not very expensive. If it turns out not to be the switches, I am sure you will get to use them later on anyway. BTW, thanks to Wayne (Oh Ha Ha) and Bill (wcc)-my windows now work great!!!!!!!!!!
Mike
