raw power's Avatar
door window trim 1984 Carrera Targa
Please point me in the right direction, I need the top corner rubber pieces that seal the front top corners of the side windows. mine are old and unsightly. The passenger door is undergoing a face lift and now is the time to replace this small corner du-dad. Searched threads in here with no specific info. See pics, Car not looking it's best right now but won't be long Thanks
Old 06-05-2006, 09:32 PM
I just purchased these also. Hope this helps.
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_BDYsl3_pg2.htm
90 - Targa Vent Window Cap / Corner Seal
Now, If someone can give me advice on how to remove the old cap and install the new one that would be great.
Stephanie
'86 911 Carrera Targa
Old 06-07-2006, 04:49 PM
raw power's Avatar
You have to take the frame apart. the rubber is impregnated onto a 90 deg. "L" bracket which is rivited to the frame section. I have the whole corner window removed from the door and completly dissasembled. Not a huge job but a little more than I bargined for. Thanks for the link, I had just found it. I needed to look a little harder.
Old 06-07-2006, 04:55 PM
