pmajka's Avatar
When it Rains: 930 owners?
When it rains, should my Teacart (turbo tail) drain? if so where.
when i wash the car , it fills up with water and slooooooly drains from top, leaveing waater in the tail over rear hood.
Have you ever felt suffocated while watching the Oxygen Channel?
People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself.
88 Carrera
Old 06-07-2006, 10:32 AM
pmajka's Avatar
bump
88 Carrera
Old 06-07-2006, 03:10 PM
Wash. State
nesslar's Avatar
Good one! I suppose model 930 washers would spin so fast you could throw away the dryer?
Larry
'86 Targa
Old 06-09-2006, 01:18 PM
Wider is Better
wholberg's Avatar
The water drains runs down through the grill where it is sucked up by the fan...it's called water injection ;-)
Wider is Better
Old 06-09-2006, 01:42 PM
pmajka's Avatar
seriously, is it supposed to drain through something or where the tail meets the rear deck lid?
88 Carrera
Old 06-09-2006, 01:44 PM
Wider is Better
wholberg's Avatar
OK, seriously, when it rains the water in my tea tray spoiler runs down into the engine compartment, where it drains out around the motor. I never have any water collection on top, except maybe a little puddle is the spoiler corners that goes away as soon as I start moving.
Wider is Better
Old 06-09-2006, 03:42 PM
Sweeny Todd's Avatar
Would a Porsche washing machine use water?
Hal
Old 06-09-2006, 03:50 PM
SC washing machines would spin the opposite direction.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 06-10-2006, 06:43 AM
pmajka's Avatar
Wholberg.. thanks for replying seriously.... I know water will fall on the engine, but there is that 8" x the width of the base of the tail on the deck lid that could potentially hold about 2 gallons of water.
If i wash my car, it only drains to the outside running down my rear decklid and if i were to open the decklid, i just soaked my engine and the electrics.
88 Carrera
Old 06-10-2006, 07:06 AM
pmajka's Avatar
Sweeny, ...hmmmm..itd have to be a 996 or better i guess.
88 Carrera
Old 06-10-2006, 07:09 AM
84porsche's Avatar
Send a message via Yahoo to 84porsche
If you have an air compressor or a wet/dry vac, when you park (in a garage) get that cleaned/sucked up or another option would be to drill a small hole to drain or run a hose drainage system from the inside portion of the decklid down to the ground.
Modes of Transportation:
1984 Porsche 911 Targa
2003 VW Jetta GLI
Old 06-10-2006, 11:26 AM
