bcr4d's Avatar
keep blowing fuse
My 88 cab keeps blowing the same fuse. My left front fog light and the rear left tail light went out, so my first thought was the fuse. I found that the fuse for those lights were blown, so I replaced it and it blew again. I thought maybe I messed it up when I put it in, so I put another one in and it did the same thing. Any thoughts anyone. I don't want to get pulled over for something simple as that. thanks in advance.
Billy Crawford
Old 06-09-2006, 07:15 PM
ianc's Avatar
You've got a short somewhere. Start by pulling the lenses on both lights and looking at the wires to see if they may have rubbed through somewhere.
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 06-09-2006, 08:05 PM
Air Medal or two
afterburn 549's Avatar
K.i.s.s..I have had a light that was shorted out inside...after much frustration......the last place you look.......
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 06-09-2006, 08:42 PM
What size fuse are you replacing it with?
Nick
'85 Carrera
Old 06-09-2006, 08:48 PM
bcr4d's Avatar
reply
I'm replacing it with a 5A.
Billy Crawford
Old 06-10-2006, 03:35 AM
Hmm
Side Marker lights are 5A.
Fog lights are 16A
Pull all of your left side marker bulbs out and put another 5A fuse in there and turn on the lights and see if it blows again. If it does, you will want to get a lot more fuses.
You get to find out which wire wore through or which lamp assembly is grounding out.
If removing all bulbs doesn't solve it, You will need an Ohm meter and check each socket connector (the little positive one and see which one is grounding.
Good luck.
Nick
'85 Carrera
Old 06-10-2006, 11:00 AM
