Lowered the Rear end
Ok, i'm continueing my education on discover your limits.... I lowered the front suspension including re-indexing the front torsion bars. That went ok.
then, To quote raceProEngineer- "the rear is much more difficult and takes considerably more time" No joke! after reading three different published articles and three or four threads I decided it was within my abilities (except the corner balance and alignment). 4 nights later and it's still not right. Getting the da** spring plate stuff loose and off the first time was almost impossible. (Two mechanics; my ass, wayne!) started out around 27" rear ht now its 24.25". The first attempt put the wheel well on the tire! Now its about 1/4 above the tire on the rt and 1/2" above the tire on the Lft. Target ht is 25" in the rear. I have no clue as to how jacked up the camber and Toe-in will be when i'm done. I hope I don't have to drive far to get it balanced and aligned. It sure looks better though. Last pic is starting point. http://forums.pelicanparts.com/uploa...1149561716.jpg http://forums.pelicanparts.com/uploa...1149561762.jpg http://forums.pelicanparts.com/uploa...1149561800.jpghttp://forums.pelicanparts.com/uploa...1149561874.jpg http://forums.pelicanparts.com/uploa...1149561916.jpg |
Your OK
Go back and re read the alignment stuff you can set that too. Your almost there! I would suggest getting it close then take a week off. It will go much better after a few days to clear the head! |
| All times are GMT -8. The time now is 01:48 AM. |
