charcoal scrubber
I removed the black cannister from the upper right hand corner of the engine compartment. It is obviously meant to clean the gases coming from the crankcase. It is filled with granuales of charcoal. Do these need to be replaced from time to time? I can't find any reference to it in the Haynes manual and I can't find a listing for this part. Any help appreciated.
Old 07-16-2006, 04:50 PM
19 years and 17k posts...
azasadny's Avatar
What year car? What engine?
Art Zasadny
Learning the bass guitar
www.ford.com
Old 07-16-2006, 07:11 PM
Somatic Negative Optimist
Gunter's Avatar
Should we guess on the year/type?
Before you continue, this canister could be for fuel-vapor coming from the front.
PCV is achieved by the hose from the breather cap to the oil filler stud and another hose from the oil filler stud to the black boot on top of the air flow sensor/TB.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 07-16-2006, 07:57 PM
randywebb's Avatar
The activated carbon in the canisters can replenish itself many many times. How many years or decades it will last before it needs to be replaced, I don't know.
On some models they are NLA but can be obtained from VW for about $80.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 07-16-2006, 08:03 PM
Sorry for the lack of information: 1977 - 911S 2.7litre
Old 07-21-2006, 03:39 PM
goldgunner's Avatar
As noted above, the charcoal container is not for the crankcase, but is for fuel tank vapor ventilation and recycle into the intake manifold.
As far as activated charcoal/carbon replenishing itself, from what I've read it's not 'self healing' or 'self reactivating'. You could use activated carbon / charcoal typically sold for aquariums, but it's a MUCH larger granule size. I was unable to find smale granule size like the oem.
After 25 years I reckon the pores in the charcoal were clogged with fuel varnish...
I've read the only way to truly reactivate the 'activated carbon' is under fairly extreme pressure and heat. Conceivably you could use a pressure cooker if you could get it to 1800 degrees F.
I took the maybe it will, maybe it won't - but it won't hurt method:
Divided the carbon into about 4 equal amounts, spread on a metal lipped pan, and gave it as much acetone as it would seem to absorb and lite it. To me, being somewhat familiar with how acetone burns, it appears that I was getting meaningful and significant residual burn and flame beyond what the acetone would have represented. To me, that meant that the varnish had become volatile and was flamed and burned off. I did this for all 4 quarters of the carbon quantity and refilled and reassembled the container. I figure at worst - no worse than it was; at best, it might have sufficiently burned out the clogged pores to allow for some more years of vapor absorption.
YMMV, regards,
Jim
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R
________________________
2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI
Old 07-21-2006, 05:45 PM
