Does the 915 gasket kit contain the CV joint gaskets? There was grease on the flange when I separated the trans from the CV joint, do I need to repack this, or does it come from the joint itself? Another thing, the diagram for the flange bolt shows only 4 bolts, I have more. Are these still the correct bolts with just a diagram for position? Thanks in advance. Trans parts got to Toledo tonight, should be here tomorrow.
Cheers, Mike
1981 911 SC Black / Black & Tan sunroof coupe. Run like the wind...straining the limits of machine and man... (Peart) |
Autobahn Garage
flange gaskets are not included it the trans gasket kit. Yes you should put a little grease back in the joints when you reinstall, Bolts should be fine. Toledo? Ohio? I live about 40 miles south of there
T Tanner 76, 911s w/ Webers 76, 914/4 57, Speedster |
Thanks for the input. I bought my car from Maumee, Ohio. Wish I knew about PPI's. Cheers.
Autobahn Garage
Let me know if I can be of any more help. best of luck with you car!!!!!
