Help Installing Throttle Body on Carrera
I have an enlarged throttle body that I'm planning to install on my 85'. Haven't found any help in the Bentley. What items will I want to replace when I take the old throttle body off? I was expecting to find a gasket that goes between the body and intake, but couldn't find one here at pelican. The throttle body I had bored out was bought used. Should I put any of the switches on from the old throttle body? Thanks in advance.
85' 911 Coupe
sw chip, ghl sport cat, M&K sport muffler, short shift, magnecor wires, heat sheets, cool collar, Momo anatomic leather shift knob...
Old 06-07-2006, 04:22 PM
MBruns for President
JeremyD's Avatar
There is a round rubber gasket from the throttle body to the intake. And it's pretty plug and play - although you will probably need a chip (steve wong) to take advantage of any increase in Air///
Old 06-07-2006, 05:07 PM
This look like the right part?
http://www.pelicanparts.com/cgi-bin/smart/imgdsply.cgi?pn=99970112440-M17
Pelican says its from throttle body to airbox. But that doesn't make a lot of sense since they aren't connected.
85' 911 Coupe
Old 06-07-2006, 05:13 PM
Friend of Warren
I think the description is incorrect. That appears to be the rubber o-ring between the throttle body and the intake manifold. There is a traditional paper gasket between the airbox and the AFM.
Kurt V
Old 06-07-2006, 05:40 PM
throttle body
Anything I should replace while I have it off?
85' 911 Coupe
Old 06-07-2006, 05:57 PM
JeremyD's Avatar
You can see the slot for the o-ring in the top of my intake manifold
I got mine in a "top end" kit
It looks like this
Old 06-07-2006, 06:09 PM
JeremyD's Avatar
Re: throttle body
Extrude hone?
Old 06-07-2006, 06:10 PM
