Need help with oil tank identification
The oil tank on my barn find 911 restoration has two additional ports (behind 34,33 in the picture) to connect oil lines. I'd be most grateful for your help to:
1. Identify the origin of the tank (which model had it installed)
2. What gets connected to the two ports.
These have been pinched shut and soldered closed on my tank.
Thank you in advance for your time!
Old 05-25-2015, 06:02 PM
pors1968's Avatar
Sportomatic outlet hose.
Old 05-25-2015, 06:33 PM
Thanks pors1968-would one be oil inlet, other oil outlet? ..... And how did Sportomatic box use oil?
Can I use these for turbo oil supply?
Thanks!
Old 05-25-2015, 09:03 PM
pors1968's Avatar
It could be a turbo oil tank if your tank look like the one you show but if you have a pict i can check i have both in my stock .
Old 05-26-2015, 03:38 AM
I'll have to remove to photograph. Thank you for your offer!
Old 05-26-2015, 10:18 PM
I'll have the same oil tank in my 1969 sporto.
the extra connections go to the torque converter housing
Old 11-23-2015, 12:32 PM
