1987 3.2 dies then runs ok Help !!
when driving along without warning the engine dies completely
its like there is no gas or no spark don't know which it will normally start right up and be OK for a day or 2 days or a week then same thing again anyone had this happen, ? all help welcome thanks Mike
Try replacing the DME relay under the driver seat. That relay often fails over 10 years of use especially if you have had water enter the car. Most wise owners of 3.2 carreras carry a spare relay (about 40-50 bucks) to avoid being stranded when the fuel or spark is cut off by the relay failing. Next check spark plug wires and change fuel filter if that were never done or maintenance was due.
along with the DME relay, be sure that the head temp sensor has been updated to the one with the fat wire and double terminal plug.
can I get to that without removing the seat ? |
Yes you can.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
GFCC
I'll second the Cylinder Head Temp Sensor.
Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current |
Thanks again
what is this cylinder temp sensor and where is it located (I guess its somewhere on the head ) is this easy to replace ? |
M491 Coupe Owner
Silver '86 Turbo Look Coupe |
UFLYICU
CHT can be reached from the driver's side, under the car. Remove rear wheel, and look for the sensor poking out of the #3 cylinder (closest to driver) head. It should require a slotted deep socket to remove due to the permanently attached lead that comes out of it and goes up to the bracket behind the heater blower motor. I just ground a slot in an old socket for this purpose. Your symptoms seem more likely to be caused by a bad DME relay, however. I would try that first.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Um, Ah, if you are trashing the old oh two sensor, chop the wires and use a regular deep or dare I say an adjustable ( metric) to get it out.
Ned NYNA 11 87 Carrera targa 98 BMW 528i 98 Volvo V70 |
UFLYICU
Um, ah... what does the "oh two" sensor have to do with this thread?
The CHT is actually fairly easy, if you have the correct tool. I bought a deep well socket at Harbor Freight and cut a slot in with a dremel.
(I'll post a picture later)
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint |
Turgid Member
Had your exact problem a few years back. Would randomly die while driving or sometimes just buck like a bronco for 3-10 seconds and then either die or run fine. After replacing all the usual culprits (DME relay, CHT sensor, flywheel sensor, plugs/wires, etc.) and still experiencing the problem, I finally gave up and took it to my wrench. He was stumped too, as the problem was very intermittent and difficult to corner. Two weeks later, he finally narrowed it down to the fuel injection harness. Replaced it, and she ran like a scalded dog.
Bonus: all new sensors and relays..... Good luck.
'87 Carrera "Man who go through airport turnstile sideways going to Bangkok" |
Friend of Warren
CHT sensor replacement tech article: http://www.pelicanparts.com/techarticles/911_cyl_head_temp_sensor/911_cyl_head_temp_sensor.htm
Kurt V No more Porsches, but a revolving number of motorcycles. |
Thanks to everyone who replied
I changed the DME relay Sunday and so far ...... it has been perfect in fact it hasnt run this smooth for 12 months so thanks again Mike |
UFLYICU
You bought two and put one in the glovebox, right?
If the engine is completely dead at times, it will not be the temp sensor.
I had identical symptoms that disappeared after replacing the DME relais.......good chance you're ok again. |
when i hear 1987 911! that sure woke me up! quanity (1) new style w/fat wire and double terminal plug cylinder head temp sensor ordered! i aint getting stuck in BFE! well i'll at least try like hell not to! thanks for the TOP TIP! thats whats great about this site....................der stuffen wir nicht ge-thinken about!
I second the "not the temp sensor" sentiment.
It's more likely to be the ignition switch, then the dme relay. I'd start by changing the relay because even if it's not the relay, you'll have to replace that eventually anyway. |
UFLYICU
Rusnak, you realize the problem was fixed by replacing the relay, right?
