Guest
Posts: n/a
911 fresh air blower proublem
1979 911 coupe.
my resh air blower is not workinking. All the leads from the switch to the blower seem ok but I get no power.I applied direct 12v power to the blower (after disconting the four post pron) and nothing happened. I went from what I thought was the ground position at the blower (in relation with th blk wire position from the plug) grounded it applied 12v and nothing happened.This really suprised me. Is there a relay I"am missing. Does anyone know the color code of the hot wire from the blower to the fuse box?Any clues would be appreaciated. |
Guest
Posts: n/a
If you applied direct 12VDC to the plug at the blower and nothing happened I would assume you have a bad blower motor. I've never messed with the fresh air blower in the front luggage compartment, but I've had problems with heater blower @ engine compartment. I applied 12VDC to the motor. Once I knew the motor worked I traced the wires. Tough job! I found a bent contact at the heater levers next to the hand brake (82 911SC). Bent them back... it works fine now.
