durn for'ner
livi's Avatar
Brake fluid change success. Good old method. Pic.
Changed brake fluid today. Decided on the gravitation method. Worked like a charm. Started right rear, then left rear, right front and left front. Picked up a short piece of hose and a liter of brake fluid. Arched the hose with a bit of string to avoid air entrance. One end on the nipple the other pointing down into a bottle. Opened the nipple but the fluid came out in slow drops and being alone I was afraid of pumping the pedal and draw air in threw the container. With a little trial and error I worked out a system where I pumped 6-8 times on the pedal. Filled it up again. And so on. Rear right (chicken with the pedal) took forty minutes. Faster wheel by wheel, so left front took only ten minutes. In total almost two hours including jacking up the car, removing and reinstalling the wheels. Next time I will do it in 45 minutes total.
The pedal feel and brake effect is much better. Feels safe!
Here´s a pic of the setup.
Markus
Resident Fluffer
Carrera '85
Old 06-10-2006, 01:16 PM
Ahhhh..another convert to the simple, reliable, slow ( but good !) gravity bleeding method......nice job !.
Hint...next time use flare wrenches...don't risk stripping the hex on these buggers...
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 06-10-2006, 05:54 PM
durn for'ner
livi's Avatar
Thanks Wil !
That little bugger nipple needed a 9 mm wrench. I have dozens of sizes, but could not find a 9 mm for my life in the garage. Was about to give up and go to the store, when I came to think of the original tool set in the front compartment. And what do you know, there it was! Not flare, but still.
Markus
Resident Fluffer
Carrera '85
Old 06-10-2006, 11:57 PM
I too have an 85...but I thought these were 7mm..... I'm not certain they are, but that was my faint recollection.
- Wil
Wil Ferch
Old 06-11-2006, 10:23 AM
durn for'ner
livi's Avatar
My garage 'collection' included several 10 and 8 mm. Reminded me of my time in the Swedish Army. Their clothing outfits came in two sizes: too big or too small.
BTW, in the master cylinder reservoir, I suppose the 'high' level corresponds approx. to the 'ceiling' of the reservoir ? But I can´t figure out where the 'low' level mark is ?
And, holy smoke, these little cars have tremendous brake power. I am literary hanging in the belt now.
Markus
Resident Fluffer
Carrera '85
Old 06-11-2006, 11:37 AM
Ahhh another timely post as I'm just about ready to do the same thing. I've got some ATE Gold to replace my ATE Blue. Can I ask about the sequence of steps? Let me know if I've got this right (or wrong):
1. Place car on 4 jack stands
2. Remove 4 wheels
3. Siphon most of the existing fluid from the resevoir under the hood?
4. Fill resevoir w/new fluid
5. Starting w/right rear - hook up hose to nipple on brake caliper as shown in photo above (thanks for the image)!
6. Loosen nipple and wait?
7. Place block under brake pedal to prevent full motion - to the floor
8. Gently pump pedal a few times to help the fluid get going
9. Check resevoir often to make sure there's always fluid so as not to suck air into the system - fill w/new fluid as needed
10. When the new color fluid is flowing out of the brake caliper nipple, tighten the nipple
11. Move on to the left rear, then the right front and finally the left front.
12. Repeat as needed until a firm pedal is achieved?
Is that basically it?
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
Old 06-11-2006, 01:30 PM
durn for'ner
livi's Avatar
Tom,
Thats pretty much exactly what I did, except for no 7 - I did not bother with the block under the pedal.
Oh, and I raised car one wheel at a time. Only have two jack stands.
Pay attention where you put your hands once you get going with the constant refilling. Inevitably get brake fluid on your hands. Poison for the paint job - as you know.
Markus
Resident Fluffer
Carrera '85
Old 06-11-2006, 01:49 PM
Jim Smolka's Avatar
You forgot to give a beer to your brake bleeding buddy after the job is done.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 06-11-2006, 02:24 PM
Jeff Alton's Avatar
After? during!!
Cheers
jeff@turn3autosport.com
997 S 4.0, Cayman S 3.8, Boxster 2.7, Boxster S race car, 996, 955 Cayenne TT, 958 Cayenne TT
Old 06-11-2006, 02:42 PM
Tom:
No need to pump the pedal...just let gravity work. The MC reservoir will always be higher than the caliper, and will provide the "push".
Also no need to risk spillage and ruining paint by syphoning off the MC. No need to syphon.
If you have the flare nut wrenches...get it placed on the nipple before you attach the hose...a bit easier that way.
you can tighten nipple ( to stop flow)...so you can add new fluid w/o any timing stress. Then re-open to continue the process.
- Wil
Wil Ferch
Old 06-11-2006, 02:54 PM
DUK DUK is offline
DUK's Avatar
Listen to Wil, gravity sucks, and is always consistent.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 06-11-2006, 03:04 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
I have to say that I just helped a fellow pelican bleed before a track day at Sears, and I have to say that the gravity method would not have worked. We went around his car at least five times using aggressive pumps on the pedal before another pelican came over, and had us repeat the process while he tapped the caliper while we pumped. I was amazed to see bubbles escape from all four corners. I would not trust the gravity method.
Racer Rix Spec911.com #5 PRC Website
2005 Seal Grey 997 Carrera Coupe (Daily Driver)
1988 Venetian Blue Carrera (former Daily Driver)
1987 Venetian Blue Carrera Track Whore "Shellback Racing" (Porsche Racing Club Spec 911)
Old 06-11-2006, 04:12 PM
Don't know why it wouldn't work for you.... gravity has *always* resulted in a nice, high , firm pedal for me.....AND:
....it avoids driving the MC piston deep into the bore ( as you might when pumping)...perhaps so deep as to contact the "rough" inside surface that the piston normally doesn't see. Result?..torn seal and seal leakage. This simply cannot happen via gravity....
to each his own.....
- Wil
Wil Ferch
Old 06-11-2006, 07:38 PM
UFLYICU
ZOA NOM's Avatar
I guess, once the system is tight, I wouldn't have a problem doing it that way. It just surprised me that there was still air in the system after so many iterations of aggressive pumping. You're right about the potential damage to the seals. I might try gravity with tapping and see how it goes.
Old 06-11-2006, 08:00 PM
durn for'ner
livi's Avatar
Wil,
I started out just opening the nipple, but the fluid came out so slow, drop by drop. I believe right rear, furthest from MC would have taken at least an hour. By pushing the pedal delicately a few times I could speed up the process to about 10 minutes per wheel. Constantly refilling MC reservoir.
So, what would be the low level mark in the reservoir ? Before sucking in air ? I was probably over cautious, did not let the level go more than 2 cm below the 'ceiling' of reservoir.
Markus
Resident Fluffer
Carrera '85
Old 06-11-2006, 10:56 PM
coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
Markus, did you push the pedal with the valve open or closed?
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 06-12-2006, 12:59 AM
paslantnose's Avatar
I'm curious why no one uses a vacuum pump (mityvac) to bleed?
Far better than gravity and no chance of MC damage.
1980 911SC Slant Nose
Can you say MegaSquirt !
Old 06-12-2006, 01:32 AM
durn for'ner
livi's Avatar
Valve open, Pål.
Not sure I understand what the point would be with valve closed ?
You planning on this project ?
Markus
Resident Fluffer
Carrera '85
Old 06-12-2006, 01:38 AM
coolcavaracing.com
Kroggers's Avatar
Thank you Markus. Yes, this is another project on my list for the summer
Old 06-12-2006, 02:25 AM
durn for'ner
livi's Avatar
Yes, hmm, summer projects..
I have still not done the shifter bushings. Afraid I´ll ruin the linkage and not be able to find the gears again after fiddling with the new coupler. I am such a whoosh.
Anyway, I am also (almost) set on doing a complete maintenance this summer including the ignition parts - spark plugs, distributor cap and rotor. Air filter, engine oil + filter and (grab hold) the dreaded valve adjustment. You done that yet your self ? What kind of feeler blades did you use ?
Markus
Resident Fluffer
Carrera '85
Old 06-12-2006, 04:00 AM
