-   -   Intake manifold/ boost source (http://forums.pelicanparts.com/porsche-911-technical-forum/287627-intake-manifold-boost-source.html)
dynevahn 06-10-2006 02:48 PM
Hey guys I need to tap into a intake manifold/boost source on a 87 930. What would be the best place to tap into? I was thinking the line between the ic and wastegate. Thanks
RarlyL8 06-10-2006 08:31 PM
It is popular for folks to T into the brake booster line. Works OK and is short & easy.
Personally I prefer to tap the intake with a dedicated line. The wastegate line should work. I use the factory bung where the electric boost sending unit screws in. If you have an aftermarket gauge you won't need the factory sender any more.
