Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
What's the best way to cut fiberglass for an exhaust cutout?
I have my RS Rear bumper now, but it's not cut out. How should I trim it?
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 06-11-2006, 11:59 AM
Early_S_Man's Avatar
Porsche Crest
Cutoff wheel on arbor in Dremel tool or die grinder ... same method was used by Mark Donohue to make slight 'adjustments' to front splitter of 917/10 at the track in 1972!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 06-11-2006, 12:03 PM
Rennch on YouTube
rennch's Avatar
Ah...the ol' dremel. Well, I have one of those at the ready. Thanks!
Michael O'Neal -
Old 06-11-2006, 12:05 PM
billyboy's Avatar
saw
pneumatic body panel saw followed by a sander.
'68 911 2.2 "E" PMO Carbs, Electromotive Crankfire Ignition, Adjustable Spring Plates, turbo tie rods, Bilsteins, headers, MB911 muffler...
"The sea merely lies in wait for the innocent but it stalks the unwary."
Old 06-11-2006, 12:15 PM
Rennch on YouTube
rennch's Avatar
I don't have a pneumatic body panel saw. I have air tools...and a sabre saw. Would that work?
Michael O'Neal -
Old 06-11-2006, 12:17 PM
billyboy's Avatar
just use a very fine blade that is sharp. you don't want to make alot of heat.
Old 06-11-2006, 12:23 PM
Rennch on YouTube
rennch's Avatar
So, I can use my saber saw then? What blade do you recommend? I can go pick one up...
Michael O'Neal -
Old 06-11-2006, 12:24 PM
Jeff Alton's Avatar
Dremel with a spiral bit on it. Like a hot knife through butter and makes corners very easy.
Cheers
www.turn3autosport.com
Old 06-11-2006, 12:27 PM
Rennch on YouTube
rennch's Avatar
Jeff...Is the spiral bit conical shaped? I want to make sure I get the right one.
Michael O'Neal -
Old 06-11-2006, 12:31 PM
large hole saw. then follow with jig saw. Use plastic down cut blade. sand or file to finish.
Old 06-11-2006, 12:33 PM
Rennch on YouTube
rennch's Avatar
Well, great. Three answers, three opinions.
No shortage of that on this list!
Michael O'Neal -
Old 06-11-2006, 12:40 PM
Rennch on YouTube
rennch's Avatar
Found the spiral bit:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&P=WR&I=LXYA57
I feel like I might have a bit more control with this vs. a saw.
Michael O'Neal -
Old 06-11-2006, 12:47 PM
Zeke's Avatar
Not so sure about the control. If you had a guide, yes. But spiral cutters tend to wander. A saw can be tracked. If you use any of the above, cut a smaller hole than you desire for 2 reasons: (1) to make sure you are centered where you like (test fit) and (2) so you can smooth to your line with a less aggressive method such as a drum sander attachment to your drill motor (variable speed preferred).
Paint the edges of your cut to prevent water from entering (not a big deal, but if there are any possibilities, water will find them).
Old 06-11-2006, 01:53 PM
Rennch on YouTube
rennch's Avatar
I have a rotary fitting on my dremel that might let me get a perfect cut. I was going to attach a piece of string to a screw, and attach it to the dremel to create a "compass" of sorts. That's the plan anyway.
Michael O'Neal -
Old 06-11-2006, 02:06 PM
Try a few tests cuts with the Dremmel before. See if its easier to cut counter clockwise or clockwise. The rotation of the bit will make it wander more one way than the other. I just cant remember which way...sorry. If you can attach a "blank" (sheet metal cut to size) to it you could follow that arc. Go slow and start small. Good luck.
Mike.
1972 911T, non-sunroof coupe.
Old 06-11-2006, 02:14 PM
Jeff Alton's Avatar
emptyo, yep, that is the one. Use two hands on the tool!
Cheers
Old 06-11-2006, 03:32 PM
