MSD conversion 84-930 turbo
does the original CDI box introduce any timing changes or is it completely passive, only used to produce the spark.
Mike |
It is completely passive -- all timing modification is done by the distributor altering the reluctor relationship to the pickup coil mounted to distributor body. There is a centrifugal advance mechanism and vacuum/boost retard module inside the distributor.
| All times are GMT -8. The time now is 06:44 AM. |
