mark '87 930's Avatar
my ride in this morning...
I noticed yesterday that the car seemed to cut out when I hit some bumps. At first i thought it was me letting off the throttle... BUT... this morning, the car died twice. Once at a stop light, and next getting onto the highway. I blipped the throttle a couple of times to get it going again, and only on the third blip did it come back. Almost at the office now, and there are train tracks I need to go over, I give it a hefty push of throttle and sure enough, the car was cutting out for some short seconds.
It's most certainly electrical... where to start looking?
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 05-24-2006, 06:10 AM
Designer King
Paulporsche's Avatar
Check fuel pump relay and fuses, your ignition switch, and the round black connections on the bottom of the dash below the steering wheel.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-24-2006, 07:59 AM
be sure the overboost relay is firmly plugged in. it's the tall yellow one on the engine compartment fuse panel.
206 637 4071
Old 05-24-2006, 08:05 AM
That would cause the car to cut out even if not on boost? I was at 2K RPM, and I was under the impression that the relay was only active under boost..and cuts off the fuel pump when overboosting.
Will check it though.
1956 Chevy 3100
Old 05-24-2006, 08:41 AM
charlesbahn's Avatar
Had a similar problem. The grounding wires on the top of the engine were loose.
"Igneous Aquam et Laudi semper"
Carl Muckley
Old 05-24-2006, 09:08 AM
re-seated the relay, took it our for lunch and seemed ok after crossing the same train tracks. I love these intermittent electrical issues.
Thanks guys... hope that licks it. Very uneasy feeling when driving..
1956 Chevy 3100
Old 05-24-2006, 02:52 PM
Hendog's Avatar
When JW speaks don't ask, just do it.
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 05-24-2006, 03:16 PM
Had a similar problem. The electrical connections to the coil were loose. They were the "press on" style and had rattled themselves free.
Old 05-24-2006, 03:34 PM
My car is still doing it. Also, I noticed that it doesn't start when cold. I need to put my foot on the gas in order for it to keep running. As if the 'choke' so to speak, is not working.
Three times today, the car cut out when I was driving, and there were no bumps this time. If I pump the throttle, it seems to come back.
Thoughts, I've already re-seated the overboost relay, could it be the fuel pumps?
1956 Chevy 3100
Old 05-28-2006, 03:28 PM
Immature Member
dentist90's Avatar
Fuel pump/DME relay? If it seems to act up when you are off-throttle, and pumping throttle brings it back from a stall, could it be something to do with idle position sensor and/or idle control valve?
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 05-28-2006, 05:04 PM
The car doesn't do it simply off throttle, I could be cruising along and it dies forr about a second or two, in that time frame, I pump the throttle to get it back going. May be the relay. They're not to expensive so I may just get a spare and try it. The car was running fine all this time, I can't see it being at adjustment, more a wire/connection or something..
I will do the verifications for the cold start issue. Look into the AAR and cold start injector. I have to find out where all this stuff is. under the IC and air box?
1956 Chevy 3100
Old 05-28-2006, 05:15 PM
Anyone in the Toronto region willing to teach? I provide beer!
1956 Chevy 3100
Old 05-28-2006, 05:16 PM
one more thing... I had the A/C on today as it was hot, and that made the car die as well. Kept the idle too low and then conked out.
1956 Chevy 3100
Old 05-28-2006, 07:56 PM
Anyone???
1956 Chevy 3100
Old 05-29-2006, 06:53 PM
My car is now doing it more often and doesn't come back to life quickly. I've replaced the fuel pump relay, and resoldered the insides of the overboost relay. Could it be the distributor and or CDI ? These intermittent issues are hard to diagnose!
Car almost left me stranded yesterday, and now I'm afraid to take it! When it cuts outs, it just dies and then comes bakc 10 - 15 seconds later.
1956 Chevy 3100
Old 06-12-2006, 04:34 AM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
Fuel filter or accumulator clogged up? Just a guess.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 06-12-2006, 04:54 AM
Check the throtle body plunger, sometimes it gets durty/gummed and doesn't float as it should; also the fuel distributor plunger could be gummed out.
Old 06-12-2006, 05:55 AM
Immature Member
dentist90's Avatar
WAG here... maybe double check your battery connections? Do you lose all power (lights, radio, etc) or just engine?
Old 06-12-2006, 08:46 PM
The lights and radio stay on... the car(engine) simply dies... and then comes back most of the time before it comes to a full stop.
1956 Chevy 3100
Old 06-12-2006, 09:02 PM
Bill Douglas's Avatar
Is there another way you can drive to work that doesn't involve crossing railway lines
Old 06-12-2006, 09:06 PM
