-   -   Odometer not working (http://forums.pelicanparts.com/porsche-911-technical-forum/288144-odometer-not-working.html)
Turbo-Mag 06-13-2006 11:38 AM
Before I tear things apart I wanted to know if anyone has suggestions on what the problem is.
My speedometer works fine, however the odometer is not racking up my miles. I have driven about 60 miles and it only went about 1/10th of a mile?
any help is appreciated.
Huh 06-13-2006 11:43 AM
Which car? Get the Wayne Dempsey: 101 Projects for your Porsche 911. It gives you the fix. It is probably the big toothed gear that is turned by the electrical wormgear motor. That was what was wrong with mine. It is a very common problem. You need to take it apart to verify which part then order it through Pelican parts.
Turbo-Mag 06-13-2006 12:33 PM
I always forget to list what I have.
'76 911 915 trans 3.0ltr
Thanks Huh, I have the book and will check it out.
Tim Casey 06-13-2006 12:50 PM
If its the gear, you will know it the minute you pull the speedo apart...the gear usually will just crumble to pieces. I bought a replacement gear ahead of time and i replaced the gear and had the speedo back in and working within an hour. Just need to be careful when you remove the speedo documenting the wiring configuration, etc. If you take your time you should be fine.
khamul02 06-13-2006 01:43 PM
Turbo-Mag throw you car in your sig. It really helps other people help you.
Cdnone1 06-13-2006 02:17 PM
Anyone know the part number for the odometer gear. I have a 82 SC and need to fix mine but am having a heck of a time finding it from our host
Turbo-Mag 06-13-2006 02:40 PM
I'm new to this, how do I put my car in my sig?
jester911 06-13-2006 02:47 PM
I don't think the gear is for sale here. Do a search for something like odometer. com . They sell the gears you need.
Or send it to a speedo shop. Chances are with the age of these gauges, they need refurbishing anyway.
jester911 06-13-2006 02:48 PM
Go to the top of the page and look for the user cp button.
Click on it and follow the links.
defcon65 06-13-2006 02:49 PM
Try North Hollywood Odometer, they have all the parts and service the VDO gauges. They have a website.
scottb 06-13-2006 03:05 PM
www.odometergears.com
www.speedometergears.com
