perryift
Guest
Posts: n/a
911 SC - Front low beam out?
The front low beam on my 911 SC is out. The brights work fine. I checked fuse at it appears to be ok. Is it just a new bulb needed or could it be something else. Can the bulb be easily changed?
Old 02-17-1999, 06:46 PM
Spencer
Guest
Posts: n/a
Try checking the relay related to the low beams (look at underside of fuse panel cover) Switch the relay with a like relay on the fuse/ relay panel.(it's a black one) If it solves the problem, you have a bad relay. Buy one from Pelican.
Old 02-18-1999, 04:15 AM
Marc Weintraub
Guest
Posts: n/a
If Spencers' suggestion doesn't work, the try the following. Remember, it depends on the actual headlight setup you have on your car. I have one car with the dual bulb halogen headlights and I have blown individual lights, just as you have. If it is this type of setup the bulb replacement is easy. The headlight bucket is taken out by removing one screw (The one at the bottom of the light housing). You will see the lightbulbs and their respective releases when you look at the rear of the bucket. Pull the bulb out and change it out. You should be fine.
Old 02-19-1999, 12:52 PM
