Smart Racing Front ARB Install
Quick question: on the SRP front anti roll bar install, how did you enlarge the stock "through the body" hole? Hole saw?
Thanks, Michael |
With a hole saw and die grinder and a template made from thin sheet steel. It wasnt hard, but it took a bit of time as I was very careful not to over enlarge the hole and ensure a good fit.
What takes even more time is getting the mounts to line up perfectly side to side so there is no binding in the bar. Its a trial and error process with gentle bending of the mounts on either side using the bar itself as a lever. To get mine perfect on my '69 911S it took many hours. |
I used a drill with a special drill bit - looks like a file on the side - great for enlaging the holes a bit as well - when you tighten the mount it changes it's alignment slightly.
I bolted the SRP mount to the fender well using the 3 existing nuts, scribed the holes and the centre holes, and went to work - took about 10 minutes per side to get the basic hole made. What is harder to do is remove the 3 existing nuts on the inside of the fender well - used a small cold chisel and a ball peen hammer - and much cursing... have some ice handy for your fingers.... Centre hole was tidied up with a hand file and a power wire brush before painting. I also had some interferance to the bigger sway bar itself from the fuel overflow pipe - removed the metal u-tube completely and replaced it with a flexible hose. |
Ok...I'm going to head down to our local "super" hardware store and see if I can find a good drill bit. Also...in terms of the holes being the correct size...isn't it ok if the body hole is a bit bigger? The plate bolts onto the car, and is perfectly sized for the bar, so I would assume it's cool to skip the body altogether.
And, in terms of the bolts, I thought the directions stated to leave the fixed bolts where they were for early cars, and thread the allen bolts into the existing holes. Then use nuts/bolts for the other three. I'll go back and re-read. |
Tspringer..
I can see what you mean about the binding. It's tough to get them right! I'm starting to devise a plan and going to get back out there again. I had great luck enlarging the hole and using a rubber"stopper" grinder with a course sanding disc on it. Thanks for the help. |
It helps to have the bar and bushings in place before you do the final tightening of the sway bar mounts. I've done 2 of these and the first one was really a challange to get the alignment right. If any criticism of the SM bars is the tolerances are too tight.
| All times are GMT -8. The time now is 07:36 PM. |
