| john rogers |
02-25-1999 02:26 PM |
If the engine is running smooth, the tach is at fault and on the older ones there is circuit degradation, resisters going bad and such. On our 1974 914 I had a speedo repair shop do the tach as it bounced a lot. If you have points and the engine is running rough it could be point bounce. We use only Blue Streak points (1 set per year)in our 1974 914 and they are great. You could also check with a test tach such as a Sun, etc
[This message has been edited by john rogers (edited 02-25-99).]
