-   -   Help, Help Squealing/Screetching Sound (http://forums.pelicanparts.com/porsche-911-technical-forum/288523-help-help-squealing-screetching-sound.html)
busteif 06-15-2006 06:41 AM
I'm getting this squealing, screetching sound when I depress the clutch pedal even at idle speed. it happened to me once before for a couple of days and went away for a while, now it's back and very annoying.
at times and at low speeds when I shift I feel a hesitation a slight vibration coming from the tires as of you are driving with a flat or on the side of the highway over those inground tractions.
clutch shifts well - no issues, just the squealing sound very noticable when I depress the clutch even at stand still.
any ideas, recommendations or inputs.
thanks,
1976 - 930 with 12,800 original miles.
:mad:
fred cook 06-15-2006 06:58 AM
Squeal.........
Sounds like your clutch throwout bearing is worn out. Time for a clutch job!
Joe Bob 06-15-2006 06:59 AM
Is the cat missing?
%^B
Gunter 06-15-2006 07:51 AM
If it's the original clutch, the pilot bearing may be dry and starting to fail.
If that's the case, it will get worse to a point were the clutch will not release.
