Formerly bb80sc
Vipergrün's Avatar
Megasquirt and 3.2 intake on non-3.2 motor?
Hello all....
Anyone using a 3.2 Carrera intake and Megasquirt on a non-3.2 motor?
My thought is to use a 3.2 intake, but remove everything but the butterfly and use a TPS. I assume I could use stock injectors and fuel rails too.
I'd like to hear more on this idea, or better yet, pics if you have done it.
-Brad
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 06-18-2006, 12:49 AM
Wer bremst verliert
JohnJL's Avatar
I did exactly this and can post pics later. I am still in final assembly, so I can't comment on performance yet.
I had the intake ports on my 3.0 heads matched to the larger diameter intake runners.
I also installed a TPS, and have it connected, but will be initially using the usual MAP sensor method for initial tuning.
You need to figure out how you will mount the intake to the heads. THe Carrera intakes used 2 gaskets and a phenolic spacer. If you use those, the head studs will be too short. I used just one gasket and kept my existing studs.
I also had the intake powdercoated. It looks great, but if you do this be sure the mounting surface on the intake is taken back to flat, bare metal.
You will also need to grind a bit off the heads' injector "notch" or your injectors will be partially blocked.
THe carrera intakes have lots of spots for mounting the fuel rails.
I'll post pics soon.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 06-18-2006, 01:34 AM
Formerly bb80sc
Vipergrün's Avatar
Thanks!
If one were to use all of the gaskets and the spacer, swap the studs to longer ones, would the heads still need to be notched? Or would the injectors clear?
Cheers
-Brad
2015 Cayman GTS
Old 06-18-2006, 01:45 AM
Wer bremst verliert
JohnJL's Avatar
You would still have a "shelf" where the spacer is wider at the point where it meets the head. You can smooth it out easily with a dremel, but be careful to do each head exactly the same or you will have uneven flows between cylinders.
Old 06-18-2006, 02:25 AM
DUK DUK is offline
DUK's Avatar
Do a search on "al lkosmal" he has several posts on his 3.2 intake on a 2.7.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 06-18-2006, 05:47 AM
