tangerine911S's Avatar
Question Cold Idling problem
I have replaced my MFI with PMO's. On cold start-up I slowly pump the gas pedal a few times and turn her over at about quarter throttle. I have to rev her to about 3000 rpm initially to keep her from dying. Then I have to keep the engine at about 2000 rpm for at least 5 minutes to get her to idle. My question is, is this normal or how can I fix it. Also, at stop signs and lights, if it put it in neutral from third gear or higher rpm's, the revs drop fast and sometimes the engine dies again. I have to do some fancy footwork to keep this from happening. What is the problem I am trying to fix?
Brian
Old 06-16-2006, 09:20 AM
ianc's Avatar
Carbs are the problem you're trying to fix.
Sorry, couldn't resist. Good luck and I'm sure someone will chime in with some help for you,
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 06-16-2006, 10:56 AM
bump
Old 06-16-2006, 03:16 PM
Wer bremst verliert
JohnJL's Avatar
What is your fuel system? Did it start happing all of a sudden or a long-standing issue? What temperature is it outside or in your garage?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 06-16-2006, 04:16 PM
Its been happening for a long time, even when i had MFI if i remember correctly. Witht the MFI, the engine died all the time when taken out of gear. This is why I have the PMO setup. Starting temp is between 60-80 deg F in the garage
Old 06-18-2006, 07:22 AM
