-   -   Ignition Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/288955-ignition-problem.html)
wright77 06-17-2006 06:57 PM
Ignition Problem
What are the symptons of a bad ignition coil or wire?
This morning, my '78 SC would crank , but not fire.
The coil wire seemed a little loose, I pulled it and the brass connectors were dull, I cleaned them up, put the wire back in and it fired up.
It is the original coil and wire I believe.
Thanks,
Bob
