-   -   A little damage today, how to fix? (http://forums.pelicanparts.com/porsche-911-technical-forum/288969-little-damage-today-how-fix.html)
84porsche 06-17-2006 07:16 PM
I picked up a little road damage today on the drive, my left driver side tire caught the fender lip and pulled it out of shape. Looks like it just cut the edge of the tire a little but no major tire damage. Is this something I can fix? I tried to push it back with a plier but it's not forming evenly. Any help would be appreciated.
http://forums.pelicanparts.com/uploa...1150600426.jpg
http://forums.pelicanparts.com/uploa...1150600450.jpg
http://forums.pelicanparts.com/uploa...1150600469.jpg
chris57 06-17-2006 07:23 PM
I have had success having companies that specialize in paintless dent removal fix this sort of thing. ie dent pro, dent magic etc
450knotOffice 06-17-2006 07:27 PM
I second that. Chris, take a look in one of our OC Region magazines for a dent removal company that does this sort of thing. I can't remember the name but they do deal with Porsches.
rrsrsr 06-17-2006 07:30 PM
I've used 'The Club' (the steering wheel locking device) to fix this on a 911SC before.
BReyes 06-17-2006 07:43 PM
Its going to require a cylindrical tube/round dolley, and prying hammering. It requires the services of a body man unless you want it to look like a total amateur fixed (or rather didnt fix) it.
First thing is decide if you can do it. Ask yourself if you have ever rolled fender wheel well lips before, and how did they turn out. its not easy to do right and looks like your tire realy did a job on it. The jack it up and massage the metal back into proper shape using body tools.
Regards,
Zeke 06-17-2006 07:44 PM
You could probably fix that yourself, but the dent pro is a no brainer. The thing is, this is going to keep happening unless you trim a litle bit of the fender return, or slightly roll it under. Ask dent man about rolling. It's not irreversable, I just unrolled one 2 weeks ago. It was stretched, so it had to be shrunk and that of course required a little painting on just the return.
Wickd89 06-17-2006 07:58 PM
Hi Chris,
Sorry about the little damage.
I have a really great paintless dent guy. He supports Dutch Treats and other shops in the South Bay. He came over when I first got the car and spend nearly 2 hours fixing one little door ding (he is a perfectionist).
Dent Express
Rich Houghton
310-415-5350
He is mobile, but stays in the South Bay. Maybe go down for lunch at the beach while he works on your car.
Take care, Luis :D
scottb 06-17-2006 08:24 PM
Another option is to call Kevin at Automotive Innovations and Restorations in Van Nuys. He's a great guy and will take very good care of you.
bigrubberjeep 06-17-2006 08:52 PM
Off road tires might be the problem. Just kiddin Chris, dent pro is the way to go.
don911 06-17-2006 08:59 PM
baseball bat. I had the same thing happen on both sides after the car was lowered. You should roll the fenders while you're doing it. If the tires are that close, it will keep happening.
slodave 06-17-2006 09:40 PM
I have a baseball bat that I am no longer using. It should work just fine. You can get smaller wheels/rims and avoid this!
:D
Good luck!
Dave
slodave 06-17-2006 10:06 PM
BTW Chris...
I think that the fender damage was a direct result of the hood badge was not fully aligned! Fix this problem and the fender issue should resolve itself.
89911 06-18-2006 04:33 AM
This is going to happen again if you don't get some things corrected, such as negative camber, lip rolling or cutting, and the right sized tires and or spacers. Usually the lip just cuts into the tire, but yours was turned to the right when you bottomed out, pulling the metal outward. Get the lips rolled when you get it fixed and try some added neg camber to start.
Nine9six 06-18-2006 05:17 AM
Milt, hit the nail on the head...Unless you address the root cause, this will continue to happen. I also believe you may need to replace your front tire as well.
ael911 06-18-2006 05:30 AM
Chris, it was really nice meeting you yesterday. Where did that occur, must of been on the way down. Some of those turns were pretty tight.
Anyhow, Milt is right, gotta roll the fenders. I have the same size tires as you and my car is slammed. The top of my fenders are rolled a bit and I run some negative camber. No rubbing at all.
Andy
84porsche 06-20-2006 03:12 PM
Got an estimate close to $500 to have the fender repaired and to have them rolled on both sides. Does anybody have pictures of their fenders rolled? Is this an essential item based on where I am at now? Apparently, I need smaller tires all the way around.
on-ramp 06-20-2006 03:16 PM
take some pliers and force it back in. shouldn't look too bad. then touch up with some paint. you're done.
KevinP73 06-20-2006 03:45 PM
Stop by this Saturday and we'll roll that back in with a wooden ball bat. As long as there isn't any damage that I can't see in the pictures it looks like an easy fix.
nostatic 06-20-2006 03:49 PM
+1 on baseball bat. Hard to tell from the pics but it only looks like the lip got pulled, no distortion of the rest of the fender. Just roll it. If the paint cracks underneath touch it up. Then roll the other side to prevent it from happening there. I see no reason to spend $500 to fix it. That's a couple of track days.
Then again, you've seen my car, so I'm not really a concours kinda guy...
JBO 06-20-2006 03:57 PM
...also it appears in the first photo that you are running some serious negative camber :)
KevinP73 06-20-2006 04:06 PM
Bite your lip!
ael911 06-20-2006 04:07 PM
It's not your tires Chris, I run the same size tires as you and my car is slammed. It's the offset of your wheels. They stick out a little too far. Consider different offset wheels or run some more negative camber if possible.
84porsche 06-20-2006 05:07 PM
Thanks everyone. I will take stop by Kevin's on Saturday.
BTW, Dave, I will order a new hood badge, one I can be proud of to show off.
84porsche 06-24-2006 05:14 PM
Kevin, it was a pleasure meeting you again and talking with you today and thanks so so much for fixing my car. Just got home after a few other stops and she looks just as great as ever. I owe you.
