Porsche Crest reseal 3 piece BBS wheels in NoVa
Anyone know a shop in Alexandria, VA that can take apart and reseal 3 piece BBS wheels. They are 9 and 11x15. I know most conventional wheel shops do not want to deal with these.
Thanks,
Matt
Old 06-18-2006, 07:05 AM
gestalt1's Avatar
just do them yourself - its easy. un-bolt the center bolts, take apart and clean everything. re-assemble using silicon sealent from the hardware store. it would be a good idea to replace the bolts. you can get them from hoerr racing.
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 06-18-2006, 07:12 AM
Neil Peart Fan
Pele911's Avatar
IMA Motorsports in Merrifield, VA is a good place but i agree with doing the work yourself being a good idea.
Old 06-18-2006, 07:32 AM
89turbocabmike's Avatar
Definitely give it a try yourself Matt. Generally accepted torque values for the bolts are 14lbs and get some high quality silicone sealant designed for aluminum from lowes/HD etc. Clean the mating surfaces, bolt together and then a nice bead of silicone smoothed over with your finger over the part lines after you scotch brite the area where the silicone will be. It's best to have the tires removed first or at least have the beads broken for you.
Old 06-18-2006, 07:55 AM
J Smith's Avatar
Use a Permatex product called "The Right Stuff" instead of silicone to seal them back up. It's available at most automotive shops (Autozone, Pep Boys, etc.)
Josh
'87 911 Carrera 3.2 Coupe
Old 06-18-2006, 08:32 AM
Porsche Junky
mede8er's Avatar
I'm going this route.....
http://forums.pelicanparts.com/porsche-911-technical-forum/287766-leaky-bbs-wheel.html#post2645594
1986 930 RUF equipped
Old 06-18-2006, 10:14 AM
Thanks for all the replies. I have the bolts and some sealant. I just remember watching a shop have trouble putting them together, possibly due to the size of the tires. I may give it a shot next weekend.
Thanks again,
Matt
Old 06-19-2006, 04:10 AM
