Have914
Guest
Posts: n/a
How does one install the quiet Kit?
Ordered that quiet kit for my '74 Carrera's doors. Damn kit does not come with instructions of where to install those little plastic tabs. I figured out where the rubber stoppers go (under the door). Can anyone show me photos or a diagram that shows where to place these tabs? Or maybe someone that has done this?
Thanks all!!!
Old 04-22-1999, 10:21 PM
Hence
Guest
Posts: n/a
I have seen a couple door "quiet kits." It sounds like you have the one that installs on the coupe window frame as it enters into the most frontward part of the door. It sort of wraps around the window frame, and is held in place by a little plastic pop-rivet thingy. You may be confused what to do with the parts because your car already has them!
The other thing is a plug that fits into the bottom of the door, in the hole that is about 6 or so inches from the front of the door.
[This message has been edited by Brian Kumamoto (edited 04-27-99).]
Old 04-27-1999, 12:08 PM
