-   -   What do you think? (http://forums.pelicanparts.com/porsche-911-technical-forum/289224-what-do-you-think.html)
rs6er 06-19-2006 02:25 PM
What do you think?
I bought SSIs on ebay and ordered an M&K. Not very experienced working on my Porsche, I decided to do it myself after reading posts here and after Jason from Pelican told me he's never broken a stud on an 81-83 SC exhaust and has done several. I live in the snow belt, and my barrel nuts, heater valves, etc. are quite rusted. Well, I snapped the stud on the first barrel nut I tried. It's also tough to use heat underneath a car resting on jackstands. Should I quit while I'm behind and get a pro to do it? (I also need to change the heater valves.) :confused:
Dan in Pasadena 06-19-2006 02:37 PM
Since you're in the snow belt, I'd leave it to a pro. But I'd get a LOT of references. No need to pay someone to break them, you're already good at that! Best of luck.
P.S. That's assuming you did all the things you were supposed to do. Soak them with PB Blaster or Kroil repeatedly for a week. Use a MAPP torch and use it properly, etc. Did you?
rs6er 06-19-2006 03:31 PM
Um...
Anyway, I have a first rate mechanic.
lally911 06-19-2006 03:35 PM
I'd leave it to a pro. It was tough with the engine upside down on a stand. Even then I had problems with a couple of them. Its going to take more heat than a mapp gas torch as well. The nuts need to be glowing dull red. Sears sells a small oxy-mapp torch which gets hot enough. If going this route buy plenty of oxygen bottles because it goes real fast.
Good luck.
rs6er 06-19-2006 04:03 PM
Keith-
I see you're from Brookhaven. Do you know Dave Hammer at Werks I in Seacliff?
John
Zeke 06-19-2006 04:34 PM
+1 on the heat to dull red. And, as it cools, I spray the PB on it. Seems to suck it up that way after the initial burn off. Never had a fire yet, YMMV, keep an extinguisher handy.
lally911 06-19-2006 05:07 PM
I also had a helper trying to crack them loose when I had the torch on them. It was a real pain in the &*^ job.
sorry, haven't met Dave yet.
A Quiet Boom 06-19-2006 05:12 PM
Get them to a dull red and pull the exhaust. If you break anymore I sell a tool that you can use to fix the broken ones. It's a real crap shoot trying to drill the studs freehand, the tool guides the drill right down the center of the stud.
johnnyo 06-19-2006 05:16 PM
John, I sent you a PM with my phone # I have someone local who can help you out, Johnny O
johnnyo 06-19-2006 06:22 PM
Hey John, Just to add you may need to research back dating two oil lines to accomodate the SSI, Johnny O
rs6er 06-19-2006 06:28 PM
Thanks. I know about that.
