m_wuebben's Avatar
Question Clutch travel hardware w/ new floorboards?
I just did some trans work. My floorboard is not good and has no pedal adjustment stops. If I buy a new floorboard, does it come with the hardware to adjust the clutch pedal travel. If not, where do I find it? I can't find it in the catalog. Thanks. Cheers, Mike.
1981 911 SC Black / Black & Tan sunroof coupe.
Run like the wind...straining the limits of machine and man... (Peart)
Old 06-20-2006, 11:18 AM
Zeke's Avatar
New wood floorboards are NLA, AFAIK. Generally one buys a plastic replacement and transfers the hardware. Again, I'm not postive on that, because I didn't buy the plastic one. Then, there's the aluminum models that come complete. Best best is to buy a good used board from one of the dismantlers. Specify that you have a coupe if they don't ask. It will come complete. Save your old hardware if you have it. Might come in handy someday.
BTW, I have patterns for all of the floorboards, but as they require bending, making them out of wood is a task.
Edit: sorry, I misspoke. The pics in Pelican's catalouge show no hardware with the AL boards either.
Old 06-20-2006, 11:55 AM
randywebb's Avatar
I'll add:
drill the rivits out to reomve the mounting plate
If the layers have just separated, you can use Gorilla Glue to mend them - clamp pretty quickly
The Al replacements don't save any wt. and are hot in the summer and cold in the winter. Some like the looks however.
Or get the plastic ones.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-20-2006, 01:15 PM
I rebuilt my Targa driver's floorboard, which was a mess, including fabbing a new clutch pedal rubber stop buggy bumper. Last post in this thread.
Brian
Old 06-20-2006, 01:36 PM
m_wuebben's Avatar
Thanks for the info, I'll try to do that. Cheers, Mike
Old 06-20-2006, 05:18 PM
