'78 SC targa and cab doors same?
Would the doors from a hard top interchange onto a targa with the removal of the window frame?
Old 06-21-2006, 08:14 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
As far as I understand what was done with my car; the doors were replaced with Cab doors off an '87, though I was told that wasn't absolutely necessary.
The major problem comes in when they have to replace the upper portion of the windsheild frame to install the proper one that has the cab mounts. Various shops and technicians do it different ways. The major variation is where they cut the side members and then weld in the new frame.
Are you converting your Targa to a Cab?
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 06-22-2006, 09:55 AM
i would like to replace my right door but cannot find any targa doors.
Old 06-22-2006, 10:50 AM
