mtnbike001
Guest
Posts: n/a
Steering Wheel
I have a 1979 911sc with the 3 spoke steering wheel. I want to replace it with a 1985 Porsche 4 spoke wheel. I know the 4 spoke has a slightly larger diameter which shouldn't be a problem but I am not sure if the splines on both wheels are the same so that it will mate up with the steering post. I also want to know if a wheel puller is necessary or if all I need to do is take off the 27 mm nut and the wheel will just pull off. Thanks in advance....Bill
Old 05-28-1999, 10:21 PM
Serge
Guest
Posts: n/a
I've had both wheels on my 78 sc, the splines are the same. You won't need a puller, just a sharp tug should do the trick.
Old 05-29-1999, 10:30 PM
