Garrison's Avatar
Oil Drops
I just purchased my first 911 and would like to know what is considered normal for oil leaks?
I drove it today for a little over 100 total highway miles and when I got home and let it sit I noticed 3 quarter to half dollar size drops of oil.
Car did not run hot today, it does not smoke, and it has had a full top end at about 84K miles. Has 118K on it now.
1988 Porsche 911 Targa.
Am I okay, is this "normal"???
1996 Porsche 911
2013 BMW 335xi - Wifes car
2007 4Runner - 4x4 for Colorado snow
Past: 1988 Venetian Blue 911 Targa, 1983 Black 930, 1984 Black 911 Coupe
Old 06-20-2006, 08:03 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
How often are the drops falling from the engine.
If its a few drops after you shut off the engine I wouldn't be too worried about it. If you're getting that size drops every minute or so (or more often) I would try to find the source and fix it immediately, or take it to a shop so they can assist you.
Check out the tech articles and past threads on how to find and fix oil leaks. They will give you a good amount of insight on this issue.
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 06-20-2006, 08:44 PM
Garrison, there's a ton of threads on oil leaks etc...lot's of helpful hints. I guaruntee you'll find info when utilizing the search feature. When in doubt post a picture of the affected area...it will help to diagnose. Do you know where the drops are coming from...? Is it the front or rear of the engine...etc...?
86' 911 Carerra
Old 06-20-2006, 09:01 PM
Immature Member
dentist90's Avatar
There are so many places for oil to get out, lets hope it's not a major engine gasket or seal. Flexible portions of oil lines (where crimped to hard lines) is a common leak point. Valve cover gaskets are another likely place. Is there any oil on TOP of timing chain covers, or is it all from below? If leak is starting at top of engine may be camshaft oil lines. I took some Gunk engine degreaser to spray away all visible oil and checked carefully each day to see what got wet with oil first. Mine was cam oil line and will be an easy fix, but until cleaned up it looked like whole motor was bleeding!
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 06-20-2006, 09:16 PM
Garrison's Avatar
After looking at it again about an hour later it was the typical drops, about the size of dimes, and it soaked into my garage floor, making it look much worse then it was.
I only get drops after the car is turned off... no dripping while running... I checked last night as well...
Took it out, got it up to temp, and then pulled over. Not one drop, the bottom of the engine was dry. I will take a hard look this weekend and try to figure out where it is coming from so I can fix the issue.
Thanks guys!
1996 Porsche 911
Old 06-21-2006, 07:26 AM
MattAlpha's Avatar
Since its only leaking when you stop the car and the engine has been off for a little while, I would say its an oil return tube seal problem.
This is the same way my leaks were being generated.
My advice is to replace all four at the same time. I replaced my rear two and now the front two are starting to leak.
There are tons of threads here on oil return tubes and some good pictures to go with them. They will help you diagnose your oil leak source.
Old 06-22-2006, 10:07 AM
Garrison's Avatar
Further information...
I got under the car last night and cleaned everything off. After drving it this morning, the oil seems to be coming from the front of the motor and running back as I drive.
Maybe a real main???
1996 Porsche 911
Old 06-22-2006, 10:25 AM
Immature Member
dentist90's Avatar
Crap.
Old 06-22-2006, 08:42 PM
