Senior Member
Anything EPA issues will be published in the Federal Register - it is a huge thing but can be searched at the EPA web site.
proudness, means proud, i.e. height is greater than the surrounding material -- old woodworking term that must be several thousand years old
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Turned On, Tuned Out
Re: Re: EPA on Zn, S and P in Engine Oil
- Sulfur (S), GF-4: 0.5 max for 0W and 5W multigrades and 0.7 max for 10W multigrades. A sulfur limit of 0.5 max applies to API SM SAE 0W-20, 0W-30, 5W-20, and 5W-30 oils and 0.7 max to API SM SAE 10W-30 oils. - Phosphorus (P), GF-4: 0.08 max/0.06 min; GF-3: 0.10 max. Phosphorus limits of 0.08 max and 0.06 min apply to API SM SAE 0W-20, 0W-30, 5W-20, 5W-30 and 10W-30 oils. A phosphorus limit of 0.10 max applies to API SJ SAE 0W-20, 5W-20, 5W-30 and 10W-30 oils and API SL SAE 0W-20, 0W-30, 5W-20, 5W-30, and 10W-30 oils. A limit of 0.12 max applies to API SH SAE 5W-30 and 10W-30 oils (SH must be preceded by a C category). If CF-4, CG-4, CH-4 and/or CI-4 categories precede SM or SL and there is no API Certification Mark, the limit for phosphorus does not apply. They do not state the limits for Zn or Mo or anything else but the API does require the analytical concentration results. How about we split the diff and call it a draw?
Inter faeces et urinam nascimur Share My Work Ethic Not My Wealth Democracy is two wolves and a lamb deciding what to have for dinner. Liberty is a well-armed lamb. |
Senior Member
Maybe theY were API at one time but not another?
How about a good ol' fashioned pizza 'n beer match? - I will offer to test both beforehand to make sure they are not spoiled.
Re: Re: Re: EPA on Zn, S and P in Engine Oil
Actually, I was not arguing your point nor the accuarcy of your data. All I was saying was that Amsoil "claims" their non-API certified oils that contain higher than max levels of Zn and P "exceed" API SL ratings. They cannot and do not display the API starburst on the label but they do have a little thing that kind of looks like it. Don
72T Coupe - SOLD :-( |
Don - Ok, but that "Star Burst" that looks like an API seal is dancing on a prrreeeettttttyyy fine line.
Senior Member
Wonder if API knows?
... infringement
Take a look at the photo in this link: http://www.amsoil.com/storefront/aro.aspx They are pretty crafty with their wording which is why some people shun them as snake oil producers. But, the products do perform and they have been fighting off naysayers for 34 years. There is lots of used oil analysis data out there that prove the product is the real deal. Don
How can I get some of the amsoil? I don't want to order online and have it shipped but will do if I have to. Can't I just go somewhere and grab it off the shelf, take it to the counter and givem a hundred?
Amsoil is sold is some retail shops but becuase of the MLM marketing program the Walmarts and Autozones of the world cannot sell it. It is sold in some locally owned Napa franchise stores and Carquest stores. You might find it listed in the yellow pages.
Vegas happens to be one of 11 cities in the states where Amsoil has a distribution center. It is not sold retail through these centers but those with proper "credentials" can buy small quanities off the shelf. Your favorite Amsoil dealer can arrange to get you the proper credentials. Don
(reviving an old thread)
Lubemaster: Do you have a recommendation at this point for oil in our cars? Scott
1984 Targa 1954 Bell 47G (the Porsche is faster but it flies lower!) |
durn for'ner
That was my question too:
Mike, what oil ?? For darn sake: WHAT OIL ?? All these oil threads make my head spin. I canīt take it anymore!!
Markus Carrera '85 |
Of course you can join the discussion here, Ultimate Oil Thread
Harry 1973.5 911T Targa "Smokey" for fun Ford Focus to drive to work Mini Van to Schlep the kids |
durn for'ner
I did and now my few remaining brain cells are smoked.
I think you have a few left...
![]() Bottom line, CJ4/SM is not a good spec for our older cars. Find something with that meets and earlier spec (SG or SL) and you will be ok. Common suggestions include Brad Penn, Swepco, ELF, some of the Mobil 1's, Shell Rimula, etc. Look at the labels. confusing, you bet and that is why I started the "ultimate" thread. There is a lot of good info there. To my way of thinking, people like Steve Weiner and Chuck have seen more engines that I ever will. I exepct them to have good filed data to support the reasearch. I, with only a sample of one engine, cannot afford to make a mistake as it will wipe out 100% of my sample.
durn for'ner
Thanks, Harry. One problem I have is that I am not sure the oil sold in Europe has the same properties as that sold in US. Also it seems very difficult to get the specific info on P and Zn contents in different oils.
Livi,
I presume the bottles show the API Ratings. If it was me, I would just avoid any that include API SM or CJ-4.
Hi there Livi, I'm in the Netherlands and ordered Swepco locally from http://www.stratson.nl/. I found them trough Google. I figured if it's good stuff there must be someone selling it over here. I'm sure you can get the good oils up north too .I suspect I could have bought the stuff cheaper online from Charles or Pelican at the current dollar/euro rates but wasn't sure about importing issues.
'82 911 SC |
Markus, Swepco is availible in Sweden too, at least the 201 gear lube.
Magnus 911 Silver Targa -77 Engine: 3.2 -84 with custom ITBs and EFI Suspension: 21/27 TBs, PolyBronze, Bilstein Rennen 1. |
durn for'ner
Good points guys, thanks!
Yes, Magnus, I have found the 201 for the transmission via that guy up north, but I donīt know if he carries other oils too. What do you use ?
After reading the oil threads I was thinking I would check with Stig if he has the 306. I'm going to order some 201 of him anyways.
Last year I ran OKQ8 10w40 semi synthetic oil out of convinience, I use that in my Audi and in my fathers Opel, I buy it cheep in 20 liters.
