Brake caliper removal w/o impact wrench?
I am redoing the brakes (rotors and pads) on my 70T. Dust cap removal was a hassle but got it done. Is it possible to get the caliper bolts off without an impact wrench? They are really tight.
Ulrich
Old 11-29-2007, 02:24 PM
Yes, you should be able to remove them w/o an impact wrench. Soak with PB Blaster, and try again. You may need a breaker bar for your socket, but they will come off.
Tony G
2000 Boxster S
Old 11-29-2007, 02:41 PM
DW SD's Avatar
use a six point 1/2" drive socket, very small extension and 1/2" drive breaker bar. Add longer outer sleeve (pipe) to breaker bar if more leverage is necessary. Ensure overlap of pipe is at least 8", preferably 12".
1971 RSR - interpretation
Old 11-29-2007, 02:56 PM
LakeCleElum's Avatar
Just pulled them of my '69 this week. Very easy w/o an impact wrench. Now, getting my stuck pistons out it a little more trouble, but I'm getting there....
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 11-29-2007, 03:19 PM
Got it off, thanks. From what I've read getting the dust cap off seems to be the hard part. Mine came off easily. Little scary - my first brake job.
Ulrich
Old 11-29-2007, 03:56 PM
glad you got it off.
remember when you use any kind of extension or breaker bar, loosen the bolt on the downward stroke, so that you can control your movement when the bolt breaks loose. If you are on the upward stroke, you can lose your balance and fall backward, causing injury or damage to the tool, car, etc.
Old 11-29-2007, 04:38 PM
Thanks rusnak. I learned that the hard way getting the springplate bolts off my old 78. They gave suddenly and I almost sliced my wrists open on the underside of the fender.
Ulrich
Old 11-29-2007, 04:45 PM
