ncseahawk's Avatar
Master Cylinder Choices
Help me out, if I am going to replace the master cylinder to run 993 brakes what it the best option available?
1985 Carrera Under Modification (SOLD)
2003 Carrera 4S
Old 09-10-2006, 06:02 PM
See Bill verburgs page:
http://www.pelicanparts.com/MotorCity/wmv/
As I understand it, it depends of you're doing front and back. This is a proportioning issue. It appears that the 930 26mm master cylinder will work.
I decided against it due to the slippery slope of cost.
After all my research and my use of the car, I decided to rebuild my calipers, new rotors, pads/sensors, braided lines (DOT approved), master cylinder.
I plan to install Front Brake Rotor Air Deflection Plates and a brake cooling kit and continue to use DOT 5 brake fluid. Thi should be more than enough braking unless you are doing serious track racing.
Good luck!
suss
cheers,
Phil
84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies.
Old 09-10-2006, 06:36 PM
Jeff Alton's Avatar
The turbo MC (23mm) will work in this application. After that you are looking at a Fabcar unit with dual MC in probaly 5/8 size. I have this MC set up bit is overkill, and big $$$
Cheers
www.turn3autosport.com
Old 09-10-2006, 09:42 PM
