khamul02's Avatar
Pelican Parts Brake Bleeding Issues / MC trouble?
Welp, I have been bleeding brakes all day with no success. All the little bubbles are gone and the fluid runs solid at each caliper BUT... my pedal is as soft as mashed potatoes.
Additional facts:
1. When pump bleeding the rear calipers, once the caliper is bleed the pedal drops to the floor. This is not the case with the fronts. The pedal doesn't drop to the floor at all.
2. When you hit the brake (even as soft as they are) the rear brakes engage. This is not the case for the fronts. It takes a second pump to get them to engage.
Theory one: After using the Motive power bleeder for about 5 cycles and good old two person pump the brake pedal technique about 5 cycles there might still be air somewhere in the lines or MC.
Theory two: The MC is screwed. A friend think that because I had it completely empty for several months one of the seals is ruined.
Additional theories ????
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 12-31-2010, 09:01 PM
Fact 1 and fact 2 are contradictory. One says the rears don't work and the fronts do. Two says the opposite.
The MC contains a dual hydraulic circuit that divides the front and rear system. If only one of the above is accurate, I would say either the front or rear piston seal is torn (leaking). This can occur during manual bleeding and the brake pedal (piston) is allowed to exceed the normal pedal travel.
This happens quite frequently if the pedal travels too far.
Sherwood
Old 12-31-2010, 11:01 PM
Green 912's Avatar
Did you do anything prior to the flush? That is to say remove the calipers and rebuild them? If so check that they are on the correct sides and the bleeders are pointing up. if so on to the next common item.
If you rebuilt the calipers with new seals you might be getting too much piston pull back. Easy fix to this. Remove one pad and pump the brake pedal just enough to make the piston move in so the pad will no longer fit back in. Now move the piston out just enough to slide the pad back in with some friction from the piston.
i like to use the pad to wiggle the piston back and the push the pad in as soon as I can force it by hand. Do this to each pad on each caliper that was rebuilt.
Old 01-01-2011, 06:42 AM
khamul02's Avatar
The rears work with only one pump and the fronts work after two pumps of the pedal.
The rears allow the pedal to drop to the floor when bleed. The fronts do not allow the pedal to drop to the floor when bleed.
BUT fluid comes out solid on all calipers when bleed. The pedal is very very soft.
Sorry for the confusion.
Sherwood, How do you avoid this from happening when you manually bleed the brakes? Should I put something under the pedal?
Green... Now that I think about it I think the bleeders are on the bottom on both front brakes.. I didn't realize they could go on backwards.. Do you think that might be the issue?
All calipers where completely rebuilt by PMB Performance. They came back like new.
Tom Hutchinson
Old 01-01-2011, 08:49 AM
GaryR's Avatar
Send a message via ICQ to GaryR
This may be your issue as I was taught by my shop that new calipers need to be "exercised". Also bleeders on the fronts are upside down, sorry I missed that on 1st look, fix that!
I assume you have pad spreaders and some old worn out pads? Put the old pads in a caliper (I started with RR as it's furthest away from MC, just like bleeding). Push the pads back as far as they go using the spreader tool. Now pump your brake pedal until they lock that wheel and are both fully against the rotor. Repeat this 5 times then move to the next wheel and repeat. Now do a full bleed and see what you get. HTH
Gary R.
Old 01-01-2011, 08:57 AM
I think Green912 asked the correct question about your rebuilding the calipers and their installation. You should have prefaced your symptoms with the complete story.
A block of wood under the pedal is good. Also do a search under "gravity bleed"
Affirmative. If the bleeders aren't at the top, air will be trapped in the caliper cavity with no way to escape. In addition, you never confessed to a firm pedal other than saying the brakes "work" (not the same).
Hope this helps,
Sherwood
Old 01-01-2011, 09:00 AM
RETIRED
Joe Bob's Avatar
I've found that walking away and waiting a day or two helps get rid of all the bubbles. Tapping the calipers with a rubber mallet is good Mojo....
I will assume that the calipers were installed with the nipples at the top?
2012 ML350 3.0 Turbo Diesel
Old 01-01-2011, 09:10 AM
khamul02's Avatar
Alright!!! Step one reverse the front calipers and see what happens..
I'm sure I will be coming back to this thread... Although it would be great it that is the only problem.
Tom Hutchinson
Old 01-01-2011, 09:20 AM
RETIRED
Joe Bob's Avatar
So....de nips b on de bottom?
Old 01-01-2011, 09:27 AM
khamul02's Avatar
They are for sure... I'm not a mechanic... I don't even play one on TV
Tom Hutchinson
Old 01-01-2011, 10:04 AM
RETIRED
Joe Bob's Avatar
Common mistake, that's why I asked. Eric should include a "Hey, Stoopid" note when he returns calipers......
Good luck.
Old 01-01-2011, 10:08 AM
I'm here to cause trouble
jimbauman's Avatar
You aren't alone... There are a LOT of members of the "Upside Down Caliper Club!"
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP)
'90 Miata LeMons Contender! '71 Datsun 510 (RIP)
'67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP)
'62 Plymouth Valiant '60 Ford Galaxy 500 (RIP)
Old 01-01-2011, 10:12 AM
Green 912's Avatar
If they are pointing down I can assure you without question this is a problem.
Be glad it is a simple fix and not the MC.
With rebuilt calipers all around, be sure to do the pad reset trick after flipping the front calipers upright. You will get a firm pedal right away and not deal with a 100 miles of mushy brake syndrome.
Old 01-01-2011, 01:56 PM
khamul02's Avatar
AWESOME!!! Reversed them and they are working perfectly.
Tom Hutchinson
Old 01-02-2011, 07:56 PM
RETIRED
Joe Bob's Avatar
Gud 4 u.....
Old 01-02-2011, 08:24 PM
Hodgey's Avatar
Joe Bob.......I love to give a good nip on the bottom...especially the Wife's...
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 01-02-2011, 08:40 PM
