rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Does it hurt the motor to drive with heat exchangers off?
I'm contemplating taking my car to a shop to have the old heat exchangers removed. (I already broke a stud and the rest are unbelievably rusted.) Would it damage anything to drive home with nothing attached to the studs at all?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 06-24-2006, 06:19 PM
hkspwrsche's Avatar
Porsche Crest yes yes
Yes it will hurt the car if you drive with no exhaust....It would be safer to drive to shop with the one exhaust stud missing. The labor to finalize the install would be cheap enough to have them finish it.
Harold
Old 06-24-2006, 06:26 PM
rs6er's Avatar
I considered that, but I thought I'd like to get in and do some cleanup with the exhaust off.
John
Old 06-24-2006, 06:31 PM
You do not have permissi
john70t's Avatar
hkspwrsche, Can you please explain furthur?
The exhaust part I agree with, because lack of backpressure would keep them stagnent, but I thought the fan pushed outside air through the shroud past the cylinder barrels and into the HE system. There, that air flow either went out the small diverter vents at the sides, or into the cabin.
If there was an easier path to vent that hot air (like missing routing hoses), wouldn't the cooling/cabin heat system function more efficiently? Please correct any mis-logic, thx.
Old 06-24-2006, 07:34 PM
