Dyno results
Dyno results for my '85. 126k miles. Never been opened. Stock Euro car with SSI's, M+K 2-1out and SW chip.
Not sure what the torque scale equates to but the curve looks great. Max power is 233.5hp
In real world driving it has heaps of low end grunt and the part throttle response is electric.
Simon
85' Carrera 3.2
02' Mazda MX5
Old 06-29-2006, 10:33 PM
A Quiet Boom's Avatar
Is that corrected for flywheel HP? Or is it making approx 267 HP at the flywheel? You're right the torque makes no sense, HP and Torque should always cross at 5252 rpm.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 06-29-2006, 10:47 PM
beepbeep's Avatar
HP and torque cross @ 5252 only if they are plotted on same scale, which isn't the case in this graph.
Seems like perfectly OK graph for wheel-corrected Carrera.
Thank you for your time,
Old 06-30-2006, 02:01 AM
do you have any before the muffler and chip??? just curious what
the muffler and chip added
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 06-30-2006, 05:18 AM
Ben,
No, unforetunately I didn't realise how inexpensive/easy it was to organize a dyno before I converted.
Steve said that the results post your muffler/his chip and SSI's was consistent with his other clients.
With your 2in1out I lose a little throttle response and a bit of top end power compared to your 2in2 out. Power wise there is only marginal differences with Euro stock setup.
But torque is increased in low and midrange.
Unforetunately my results do not give a scale that correspondes to anything I recognise. The curve does look very good and the "butt" meter definitely indicates a significant rise in low end and mid end torque.
I really do like the sound of your muffler. Not too loud down low but rising to the occasion with the rev increase. Perfect sound track.
Simon
85' Carrera 3.2
02' Mazda MX5
Old 06-30-2006, 06:36 AM
simon so what your saying is the dual outlet muffler(our brand ) shows a bit more low and top end?? I had not heard that before ! I am always interested in results like this
Ben
89 944,85.5 944
914-6werkshop.com
Old 06-30-2006, 07:04 AM
MBruns for President
JeremyD's Avatar
Better picture -
Old 06-30-2006, 07:07 AM
Thanks Jeremy!
Ben- this is part of the email Steve sent me.
"With the single out M&K muffler, you will give up some throttle response and top end power over the additional flow of a dual out system, however at the expense of a much louder exhaust note, and some resonance in the operation range below 3000._ Top end power with SSIs and a single out muffler are usually not much different over the stock European exhaust system, and can sometimes be less if the stock muffler was replaced with a sport one._ I would place peak end power of SSIs with a M&K single out to be equal to the stock Euro exhaust system._ This has been my experience so far._ My solution to this has been to have a dual out muffler, with the right side tailpipe capped when I want it to be quiet, and uncapping it if I want more power. The greatest gains from the SSIs are in the mid range where there is additional torque."
85' Carrera 3.2
02' Mazda MX5
Old 06-30-2006, 03:22 PM
randywebb's Avatar
Which Steve?
And was that based on the dyno run for your engine, or was it a general stmt. based on doing a number of engines?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-30-2006, 04:05 PM
steve wong!!!!!!!!!!
Ben
89 944,85.5 944
914-6werkshop.com
Old 06-30-2006, 07:15 PM
