WydRyd's Avatar
Question Removing Fuel Pressure Regulator?
Guys, how easy/difficult is it to remove the FPR from the fuel rail?
It's tucked away behind that left fuel rail pretty good, and I'm just wondering how the heck to get to it without an engine drop?
Suggestions?
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 04-14-2006, 08:53 PM
greglepore's Avatar
Its not fun, but its tedious rather than hard. The lines are a combination of 17 and 19mm, and the flats on the regulator are 15, IIRC. You might need to to temporarily remove the upper hose from the fitting as well. Once the hoses are off, the bracket is held on with a couple bolts w/ 10mm heads. Installation is more tedious than removal, particularly if you've got a Protomotive RR fpr, as it barely fits, and the bracket has to be bent "just so" for all of the hoses to line up. All the monkeying with the hose isn't good for old ones, I had a shop put new hose on the one from the damper to the fpr as a precaution, it was only 10 bucks or so, they reused my fittings and just used new swedges.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 04-15-2006, 05:03 AM
WydRyd's Avatar
hmmm, yeh I have the Proto RR FPR. I'm going to remove it and take the top off to check that the diaphragm isn't torn and that the piston moves freely
Merv
'89 911 Turbo Cab
Old 04-15-2006, 03:42 PM
greglepore's Avatar
Where I said "upper hose from fitting" above, I meant "filter", not fitting. It'll be obvious.
Greg Lepore
85 Targa
Old 04-15-2006, 06:04 PM
Toxic
derkpitt's Avatar
why
why would you disassemble it?
if the press is incorrect adj or replace per maintenance manual.
Bruce
88 Carrera Coupe, 12 Dodge Ram Hemi,
69 Barracuda Fastback, 68 Barracuda Convertible 5spd
The only substitute for cubic inches is cubic dollar$.
Old 04-15-2006, 06:28 PM
WydRyd's Avatar
Re: why
The Protomotive RR FPR is serviceable (they sell the internal parts to fix them), otherwise they cost USD$475 brand new
Sorry for the delayed reply. I lost track of this post. I haven't removed it as yet, being the slack b*stard that I am Hoping to do it this coming weekend.
Merv
'89 911 Turbo Cab
Old 06-25-2006, 08:17 PM
