-   -   Part # or Description - Picture included (http://forums.pelicanparts.com/porsche-911-technical-forum/290376-part-description-picture-included.html)
Pkaaso 06-26-2006 11:48 AM
Anyone know the part number or description of this?
Or, a resonable replacment or where to get plastic material to "Make Do"?
http://forums.pelicanparts.com/uploa...1151347424.jpg
http://forums.pelicanparts.com/uploa...1151347497.jpg
It's the drain tube that runs from the bottom of the heater/blower box, and goes down through the smugglers box and out the pan under the car.
Thanks in advance,
Paul
Pkaaso 06-26-2006 12:32 PM
Well, my connection at Porsche found the part number.
It's an 89' part number (911-571-224-00) but should be the same for earlier years.
BUMMER it's discontinued and not super.
So if anyone has found a good replacment, let me know.
Thanks,
Paul
oneblueyedog 06-26-2006 07:19 PM
These are the same type of material as 914 drain tubes. It's been a while but you may be able to scrounge one at a salvage yard. There are 2 located in the engine bay.
DUK 06-26-2006 07:25 PM
Paul, your not going to believe this, but tonight I was at lowe's and found the exact tube for a wash machine drain. I know it's not a p-car item, but it worked for me.
Pkaaso 06-26-2006 10:58 PM
Right ON Duke, I'll have to take a look and measure. The original measures 1" ID.
Oneblue... If the Lowes washer stuff doesn't work, I know where there is a 914 to barrow from.
Thanks,
Paul
Jim Sims 06-27-2006 03:43 AM
If you want the real stuff, Parts Heaven can almost surely remove a piece from one of their hulks.
Pkaaso 06-27-2006 08:46 AM
Thanks Jim.
