-   -   power window problem on 1991 964 C2 (http://forums.pelicanparts.com/porsche-911-technical-forum/290424-power-window-problem-1991-964-c2.html)
poorbob 06-26-2006 03:08 PM
Okay, I goofed up. I have a sticky passenger power window switch on the driver's side door panel that didn't return to the neutral position after I raised the window. In other words it remained on with out my noticing it in the up position. Now the window will go down but not up. Did I burn out the relay or the switch? I should have repalced the switch when it first started sticking, lesson learned. What to do?
dad911 06-26-2006 05:40 PM
Well you have to change the switch anyway...... You could also swap switches to debug, they are the same.
ecm911 06-27-2006 09:09 AM
dad911 is right on it. The switch - swap out to test. These switchs do this all the time. Has happened to me three times!! I now have an extra switch with my all the time.
Earl
