ignition advance with weber carbs hi
Hi can anybody help me with ignition setup for a 2.7 cis converted to webers? I know that the vacumm line has to be removed as it holds the ignition retarded at idle, but what advances the ignition above idle, does the dizzy have a mechenical advance? My motor has the origional dizzy & was a 1974 2.7 with CIS
Old 09-04-2006, 01:10 AM
Bird. It's the word...
Fishcop's Avatar
Yes, your dizzy has mechanical advance. You should time it as per CIS specs.
Cheers
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 09-04-2006, 03:17 AM
bede,
The timing specs for my 2.7L show that at idle, with the vacuum connected, the timing should be about 5 deg after TDC. The vacuum advance is good for about 5 to 6 degrees, so disconnecting the vacuum should result in an idle setting of about 1 to 2 degrees before TDC. Then revving up the engine, you should see the timing advance fairly continuously until it stops advancing at close to 6000 RPM with about 35 to 36 degrees of total advance.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 09-04-2006, 07:15 AM
Retired Member
Charlie V's Avatar
I just re-curved my dizzy on 3.0 with CIS.
http://www.pca-cwr.org/index.php?module=phpwsbb&PHPWSBB_MAN_OP=view&PHPWS_MAN_ITEMS=432
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine.
Old 09-04-2006, 08:02 AM
yrs ago with stock 2.7 CIS dizzy and camshafts I disconnected vac and plugged line then ran 5deg BTDC initial that totaled out at 35deg.
With carbs I'd try same. Now I run the 2.7 Carrera .004 dizzy. It costs around $300 new with cap and rotor. Pelican doesn't list it. You need to call them with dizzy #.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-04-2006, 09:24 AM
Early_S_Man's Avatar
Porsche Crest
bede,
The vacuum retard module provides 10° of retard, total, at idle!
Ronin provides the good data ... 5° BTDC at idle without the vacuum connected.
Here is a distributor thread with all of the data for your distributor ...
distributor lube...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-04-2006, 10:03 AM
Thanks for the help, i was not sure how it advanced but it is all clear now, no wonder you guys put a man on the moon Cheers.
Old 09-04-2006, 09:06 PM
