Guest
Posts: n/a
Crank Case Oil Leak
I have a '69 911T and oil leaks from the crank case seam and pulley. Does anyone know of an effective fix without going into the motor?
Guest
Posts: n/a
Not sure what you mean by the "crankcase seam and pulley," but if it is leaking from the rear oil seal (the crankshaft seal that is behind the pulley that drives the cooling fan), this seal can be replaced without taking the engine out of the car. You just need to take the muffler, rear sheet metal, engine mounting plate, etc. off to get access to the pulley. Take the pulley off, and the seal is just sitting right there. The old one can be pried out, and a new one carefully pushed back in. Did this last week on a friend's '86 Carrera.
Brian |
