Rubatoguy's Avatar
Send a message via AIM to Rubatoguy Send a message via Yahoo to Rubatoguy
'88 911 Carerra need new battery (Optima?)
I need a new battery for my 1988 911 Carrerra.
Currently it has an Interstate MB66-60 (550CCA, 690CA) which has been discontinued.
I was thinking about getting an Optima, but understand that these will not fit with the factory mounting system. I don't really want to spend $300 for a custom rhinestone encrusted billett titanium battery mount. Are there more reasonable alternatives?
I'd love to hear from people who have sucessfully installed Optima batteries and what their experiece has been.
thanks,
Todd
Old 06-27-2006, 11:56 PM
Send a message via AIM to fintstone
I love my optima...put one in my other cars too. You can buy a decent mount for $30 that adapts it to your stock bracket or make your own for practically nothing after seing how simple it is.
PM me if you want a link to the bracket.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 06-28-2006, 12:40 AM
charleskieffner's Avatar
grab some aluminum and a hole saw and a recip saw and then hit search. some pretty cool mounts have been made dirt cheap here. rennline has some good pics you can copy from. optimas in every vehicle we have. and some vehicles have dual optimas. we get both summer and winter extremes here and they have proven themselves. usually $110 bucks or so for red tops.
Old 06-28-2006, 04:04 AM
here's a step-by-step emedded within--->
Optima battery questions
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 06-28-2006, 05:46 AM
Friend of Warren
I used the diagram in the thread Wil posted for my Optima.
Kurt V
Old 06-28-2006, 06:08 AM
Are there more optima models these days? I was looking at these recently and thought that I saw one with terminals placed and spaced like a standard 911 battery.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 06-28-2006, 06:38 AM
I saw a company that sells a "sled" for holding an Optima in an 88.
I made a custom setup for my 89 but it was a lot of work and I had access to a machine shop and materials
Sold: 1989 3.2 coupe, 112k miles
Old 06-28-2006, 06:55 AM
Jastx's Avatar
AJUSA sells an Optima adapter. Here it is:
http://www.ajusa.com/cgi-bin/pb/view_product?prod_id=0000000160&part_number=AJR%20611%20211&model_id=0048&session_id=c9d7d7564de03d8b3d0ec4895af5fc8c
The adapter is just an aluminum piece the longer length of a standard Porsche battery to which the Optima bolts. Very easy.
My advice with the AJUSA unit is to round all the pointed corners before installing it, lessening the chance of scratching your gas tank or another part of your car as you wrestle the battery with adapter into place.
I have the Optima 34R in my 930, fits great with the adapter. Nice thing about Optimas is no chance of puking in your trunk. Well worth it for that.
John
2005 997 Carrera S -- Artic Silver/Sea Blue
Former friends: 1989 930 factory Slantnose /
1998 C4S Coupe / 1973.5 911T / 1976 914 2.0
Old 06-28-2006, 11:19 AM
John ..did you need to replace the ground strap with something longer?
Peace, Ron
www.ronorlando.net
Old 06-28-2006, 12:08 PM
Does anybody read the embedded "install" stuff...when given?
Yes...the poles are on the wrong side of the battery and a separate, longer ground strap is required. Not a biggie. The ground point is very near the battery and simply gets bolted up. Read the info given.
- Wil
Wil Ferch
Old 06-28-2006, 01:40 PM
Geez Wil..I read it all. Some say they used a longer ground cable others don't mention it. My confusion was about the different Optima Models..which made me wonder if the ground strap was no longer an issue. Sorry for the wasted bandwidth.
Peace, Ron
www.ronorlando.net
Old 06-28-2006, 02:49 PM
Southern Class & Sass
Dixie's Avatar
Here's how I mounted my red top Optima.
I bought a kitchen cutting board (because it's plastic and the right thickness to use with the factory clamp). I cut it to shape, then drilled and counter sunk some bolt holes. I bolted the Optima to it using stainless machine screws and nuts.
The net is a very nice $10.00 adapter plate.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 06-28-2006, 04:23 PM
I'd skip the Optima
Our cars have an altenator that is prone to sudden voltage reg failure and resultant overcharging that is not immediatley noticeable ( or picked up by the idiot light). Boiling an optima is a BAD thing. they blow up much easier than other batteries, its their biggest downside for use in our cars. You can get a 40 dollar battery that is a throwaway fix, as opposed to like 150 bucks for the Optima, which is less tolerant of this failure. At the very least, I'd look into some type of volt meter if I planned to run one of these in my car. It might save some gauges and electronics , too
( go ahead, ask me how I know this...)
86 3.2 Carrera Cabriolet
99 Ford Explorer Limited V6 ( disgustingly reliable) support vehicle/work truck
2000 BMW Z3 ( gone and forgotten...I got bored)
Old 06-28-2006, 06:22 PM
Jastx's Avatar
No, the R has reversed terminals and fit without modification.
John
Old 06-28-2006, 07:06 PM
Jastx's Avatar
Re: I'd skip the Optima
Originally posted by silvercar00
Boiling an optima is a BAD thing. they blow up much easier than other batteries, its their biggest downside for use in our cars. At the very least, I'd look into some type of volt meter if I planned to run one of these in my car. It might save some gauges and electronics , too
Please tell me about your experience.
John
Old 06-28-2006, 07:07 PM
"...Boiling an optima is a BAD thing. they blow up much easier than other batteries.........."
Boiling any battery is a bad thing (to do to any battery), but what's the basis for the explosive reference? My first Optima lasted 9 years w/o producing any explosive noises. YMMV.
Sherwood
http://members.rennlist.org/911pcars
Old 06-28-2006, 11:47 PM
alf alf is offline
alf's Avatar
Consider getting an Odyssey. Much lighter than an Optima and works just fine in my 88. I had an Optima, moved it to the truck
Alf
88 Carrera Coupe
Pelican Since 2002
All Zing, No Bling. ok, maybe a little bling.
The Roach
Old 06-29-2006, 03:14 AM
...In that case, I duly apologize ......
- Wil
Old 06-29-2006, 05:38 AM
Not a problem Wil ...I was just bustin' right back at ya!
Thanks John...I kind of figured the 34R was a drop in. I noticed the old postings were for earlier model batteries.
Peace, Ron
www.ronorlando.net
Old 06-29-2006, 06:33 AM
Sherwood
Try throwng 15 volts at it for an extended period of time. Optimas are particularly prone to damage from overcharging ( as are all batteries) When your volt reg goes, you won't know it ( wuithout a voltmeter) until you're stranded with a dead 150.00 battery and all battery manufacturers warn about risk of explosions from gassing-out overcharged batteries.
Old 06-29-2006, 06:53 AM
