Guest
Posts: n/a
Tree Sap Removal
Does anyone know of a good way to remove tree sap, or know of any products that will do this ? Also what is a good glass cleaner?
------------------ Joe A. |
Guest
Posts: n/a
I'm not sure about tree sap, but I know a product called Motsenbacher's Lift-Off takes old duct tape adhesive off plastic without melting the plastic, such as light covers after a race in the desert heat. Probably would do this too. I bought it at Home Depot.
Guest
Posts: n/a
It's expensive though.
[This message has been edited by john rogers (edited 08-30-1999).] |
Guest
Posts: n/a
Turtle Wax makes a good product for tar and sap removal about $3 at auto stores, most waxes have cleaners in them and will work somewhat , you'll want to remove tar and other things in your paint asap it will change the color of your finish and then put wax on to reprotect.
[This message has been edited by jryerson (edited 08-30-1999).] |
Guest
Posts: n/a
I also believe Lift-Off is effective for removing sap. Another product I would recommend is Goo Gone, which is a citrus based cleaner. I would use Goo Gone on more delicate areas like paint and upholstery.
Guest
Posts: n/a
Believe it or not, Brasso is excellent for cleaning and renewing glass,
