http://www.epa.gov/ozone/snap/refrigerants/macssubs.html And this is a link to a comparison done on several of the alternatives. http://www.ackits.com/testresults/alttest.pdf Interestingly, they don't seem to perform any better than R-12 or 134a. |
A 26 year old car with unknown refrigerant could have practically any refrigerant in it...who know for certain unless you analyze the stuff? What it should be and what it is are two distinctly different things.
My 78 SC had a conversion done by the PO in the 90's. It had R-12 in it. I put MP-39 in it last year, and noticed no difference. R-134a is a better refrigerant, if you're set up to use it, as Jim stated. If not, the costs to convert may not be worth it. Edit: Hers a link to MP-39. Notice it is for stationary equipment. I tried it in the car anyway, because inquiring minds wanted to know. http://www.dupont.com/suva/emea/products/suvamp39.html Pat |
Thanks guys
Re: How to tell if car is R-12 or R134?
One easy method to determine if the vehicle is using R134a vs. R12 is to look at the refrigerant service ports on the a/c system. On the 911/930 they are located compressor. A vehicle using R12 will have a "schrader" type valve, which has a thread on the outer diameter. Vehicles using or converted to R134a will have an adapter attached to the schrader valve stem with threads on the inner diameter. <center> http://forums.pelicanparts.com/uploa...1151756088.jpg </center> In many instances you may or many not find a sticker/label indicating the type of refrigerant. And be aware that, though not a common occurence (but we have seen everything), cars converted from R12 to R134a sometimes do not have R134a charge port adapters (difficult to do but there are hackers out there), and/or sometimes a car may have a refrigerant other than the traditional R12 or R134a. |
| All times are GMT -8. The time now is 07:36 AM. |
