thaxtela's Avatar
Thumbs down door stay damaged
The drivers door stay on my 1986 911 Targa is damaged. The door stuill closes OK however the door stay is completely disconnected on the inside of the door. I thought an option would be to purchase the door stay reinforcement kit identified in Dempseys 101 Projects however it is "No Longer Available" from Pelican Parts. Any ideas other than replacing the door?
1986 911 Factory Turbo Look Targa 3.2 litre
Old 07-06-2006, 10:32 PM
Bland
unclebilly's Avatar
It can be welded up. Where are you at?
Old 07-06-2006, 11:04 PM
Send a message via AIM to fintstone
Welding is best , of course....but the kit is quite simple and you can easily make your own if you like. The dimensions are noted in this thread:
SC Door Stop Question
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-06-2006, 11:29 PM
thaxtela's Avatar
I live in Lethbridge, Alberta, Canada.
Old 07-07-2006, 01:05 AM
thaxtela's Avatar
Thanks Flintstone and UncleBilly for the info and advice. I will investigate welding if not fabricate some reinforcement panels as you suggest.
Old 07-07-2006, 01:07 AM
Bland
unclebilly's Avatar
If you're interested, I'm in Calgary and I have a MIG welder.
Old 07-07-2006, 06:04 AM
