Terry
Guest
Posts: n/a
Interminttent Smoking
My 87 Carrera with 88,000 miles sometimes smokes while idling at a light. Its obviouly oil burning. It will then go away with no smoke what so ever. Any ideas?
Old 09-17-1999, 03:35 PM
jryerson
Guest
Posts: n/a
My Sc did the same after I first bought it, Turned out I wasn't checking my oil level after the car was warmed up enough and had overfilled it , too much oil will drain into the air box from the sump tank and into the motor
Old 09-17-1999, 04:04 PM
scott matre
Guest
Posts: n/a
My 87 does the same thing. here's what I discovered.
It smokes no matter the oil level.
If I rev it to 5500-6000 rpm and let off the throttle, I can kill bugs it smokes so much.
Turns out this is a classic sign of valve guides and seals wearing out. Apparently this happens to some 87's depending on how the car was driven (city traffic). I had a compression and leakdown test done and they are fine so I have scheduled a top end re-build. Should go in next week, I'll keep you posted.
Old 09-20-1999, 03:31 AM
Terry
Guest
Posts: n/a
I had just topped off my oil. I drained a little off and no more smoke. Thanks for the clue.
Old 09-21-1999, 02:22 PM
