A Quiet Boom's Avatar
Mix Z and W ratings on same tires?
I know you're not supposed to mix tires on 911s but I've got a problem. I've got Yoko AVS Sports on my car and the fronts are about 60 percent or better. The rears are badly worn on the inside and need replaced ASAP. All I can find are the AVS Sports in the W rating while my originals are Z rated. Sizes are 215/45/17 Front and 234/45/17 Rear. Is it OK to put W rated tires in the rear? I'd rather not replace all four tires right now, especially when the fronts are in decent shape.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 07-05-2006, 11:02 PM
lateapex911's Avatar
I assume you have 7s and 8s as rims, as the 245 is really too large for a 7" rim width, according to Yokohama. My opinion, is that the Z rating of your original meant that you were good for a max speed above 149MPH. The W rating is good up to 168MPH.
Both are probably in excess of what the car will see, I imagine.
I think there are bigger concerns with the mismatch of compounds and treadwear due to aging, but even that is rather slight...a few pounds of underinflation would be a more significant issue, and most tires aren't inflated properly.
Personally, I wouldn't sweat it. If in doubt, call the Tire Rack, or read this section:
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=35
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 07-06-2006, 12:00 AM
"O"man(are we in trouble)
widgeon13's Avatar
I did it some time ago and the car was really squirelly, unsafe at speed. I immediately took it back to where I got the tires and corrected the problem by putting the same speed ratings on front and rear (stickers had not even completely worn off tires). The sidewall construction is different in order to disipate heat and consequently they behave differently. Personally, I would not do it again but you are asking and I am giving results from real experience. Perhaps it was unique to the particular tire manufacturer, I believe I had BFG's on at the time. The car was fine once I corrected my error.
Let us know how you make out.
Old 07-06-2006, 04:58 AM
Shaun @ Tru6's Avatar
I tried to buy SO3's from Tirerack that were mixed Z and W and they wouldn't sell them to me. Said it was dangerous to mix ratings, especially if the car goes on the track where temperature plays a big role in concert with the rubber/speed rating.
Tru6 Restoration & Design
Old 07-06-2006, 05:51 AM
That is what I was afraid of. I'm going to call some local stores an see if they have any older stock. I've had these Yokos for only three years and don't know when the Z's where discontinued and the W's started. I wonder if it isn't the same tire that just passed the W testing protocol?
Old 07-06-2006, 07:25 AM
Ok, I learned something new. My tires say 235/45/ZR17 93W on the side which means they are W rated. I figured it out after re-reading the link provided by lateapex911. Boy do I feel dumb LOL. So I guess it's just a pair for the rear right now. Thanks all.
Old 07-06-2006, 02:15 PM
