74 911 Headlight highbeam switch
No low beam or high beam lights. Flash mode does work if lever is pulled toward the driver. It does not appear that power is going to copper strips. Running lights work. The fuses in the luggage area are good.
Question:
1) I was able to put a screw driver across the top two strips. The lights would work. I am no longer to bridge the strips to get low beams or high beams. Any other fuses or relays that would could be blown?
2) Is the highbeam flash circuit independent of the low/high beam wiring?
I do have a VOM.
Old 07-01-2006, 08:40 AM
HarryD's Avatar
Many threads on this topic. There is one with a picture of the switch in the steering column. THe two circuits are related but slightly different.
Try a search using "turn signal switch" as a term. You will find this thread: turn signal switch quick fix pictures
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 07-01-2006, 08:57 AM
You may already know this, but just in case.......the ignition must be on for the headlights to work.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Send a message via AIM to fintstone
Re: 74 911 Headlight highbeam switch
Question:
I do have a VOM.
Yes. Take a look at the schematic in the post below. It is a seperate circuit.
Headlamp Flasher
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-01-2006, 09:18 AM
You are right! The ignition must be on. I got the lights working!
Thanks for all your help.
Old 07-01-2006, 11:20 AM
